Question about Estate EED4300TQ Electric Dryer
Dryer not heating after power surge - Estate EED4300TQ Electric Dryer
  • Estate Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer not heating after power surge - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Dryer2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 15, 2010
Tip
If your dryer works but no heat
whirlpool,kenmore,roper,kitchenaid,inglis,if your dryer works but no heat most of the time it is a blown fuse,or bad heating coil,cause of a blown fuse can be power surge,clogged wall vent,clogged dryer lint vent box,unplug,remove back cover,look to your right and you will see the heater box,look on the left side near the top and you will see a small fuse,this is your heater box fuse,if not the fuse,the heating coil is near the bottom,1 screw on each side,remove and look for broken wire,if you have a meter,you can check the fuse and heater coil-mike
on Feb 11, 2010 | Dryers
Bosch maxx 7 condenser dryer not working after power surge. It starts but doesnt generate any heat, starts beeping and then stops. Was working fine until the power surge.
Most likely, the surge blew the internal fuse. I would try replacing that first. If you can't do it personally, have a certified tech do it for you.
May 08, 2012 | Bosch Dryers
We have had issues with our dryers circuit breaker kicking off and getting heated. About 8 months ago we had a power surge in our home and it messed up a number of appliances but we thought the dryer was...
The two items in a dryer that draws the most amperage is the motor and the heater element. Since the heat element normally either opens or is okay, it is doubtful that is the problem. Unless one of the insulators is damaged and shorting to the base.
But before you start replacing things, suggest you use a clamp on amp meter and see if the dryer is drawing more current than what the breaker is rated at. If it is then the dryer has the problem, if it isn't the problem is in the circuit breaker box.
Aug 16, 2011 | Amana NDE2330AY Electric Dryer
Runs but will not heat. Power outages in area over last few weeks.
If the dryer was running during an outage, even with a very brief flash there usually is a power surge when it comes back on. If everything else seems to work okay it's possible that the heating elements got fried. You can check them with a voltmeter. Also check to seek if the dryer has overlaod protection. Most have a reset. One other thing that could happen, the breaker is defective. That you can check at the back of the dryer where the plug cable attaches to the dryer.
Apr 09, 2011 | LG DLE2516 Electric Dryer
I have a Whirlpool electric dryer model# LER5644AWO and I just replaced the thermostat/fuse (kit 279769)because I had the heating element checked in town and was told it was the thermostat/fuse.Dryer...
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, and it checks out to be your heating element or your thermostat fuse again, you may have some wiring problems in your house (possible power surges). Check your vent from the dryer to the outside of the house - if this is clogged, it may be shorting out your fuses. Hope this helps,..Good Luck...
Nov 16, 2009 | Dryers
Gas dryer no heat
either it opened up the ignitor glow coil with the surge or the control board or flame sensor is defective
Oct 29, 2009 | Kenmore 73952 Gas Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Estate EED4300TQ Electric Dryer Logo
157 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
