Question about Jl Audio 300/4 Car Audio Amplifier
Hey quick question on JL 300/4V2 impedience light
My light comes on at extended listening levels. Is this normal? It dosent stay lit solid but acts more like a peak or threshold light. Dont know much about the light at this end. I understand loads and impedience but not the silly light
Thanks
  • Joe
    Joe Apr 02, 2008
    In theroy how much does the load of the speakers change when you are making them work with a powerful amp for an extended peripod.  As we all know resistances change with heat. but enough to make the light blink to the hard hitting bass notes?
    ZZedly thanks for the reply as I will get my trust meter out and follow the manual
    Sergeant:
  • 300 Answers
If you're referring to the orange "Low ohm" light, it's most likely caused by the amp detecting a "lower than optimum" impedance for it's gain setting. The quick answer is you'll probably have to go through the steps outlined in Appendix A of the owner's manual. This will set the amp gain and input voltage setting properly for your speaker and head unit setup.
Posted on Mar 31, 2008
  • Tygh Duval
    Tygh Duval Apr 02, 2008
    It may have less to do with the impedance of the speaker changing and more to do with the voltage level coming from the head unit. As you turn the volume up, the preamp voltage goes up. At loud volumes, the bass hits are going to be the highest voltage of them all. Appendix A should adjust the amp so that it'll be set for them.
Here's my problem, I have a belkin n300 extender, ok it worked for about a week or so and one day I lost connection, when I looked it is solid blue, even after I press reset or wps, it stays blue, I don't...
Blue?
the n300 colors.....
4 LED Descriptions
Router Link LED
This LED indicates the connection between the extender and the router or access point.
Solid green
. Best connection.
Solid ambe
r. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Device Link LED
This LED indicates the connection between the extender and a computer or mobile device.
Solid green
. Best connection.
Solid amber
. Good connection.
Solid red
. Poor connection.
Off
. No connection.
Power LED
Solid amber
. The extender is booting.
Solid green
. The extender is powered on.
Off
. The extender is powered off.
WPS LED
Solid green
. WiFi security is enabled (WPA or WPA2).
Blinking green
. A WPS connection is being established.
Off
. WiFi security is not enabled.
Note:
If the Router Link LED or Device Link LED is amber or red, Find the Best Location
Mar 07, 2018 | Belkin Computers & Internet
Extended cab Tahoe truck, 4.3l. Why is brake light on I/P dimly lit?
Possible brake fluid level warning sensor problem in the master cylinder. Disconnect the wiring harness from the sensor in the master cylinder. If the light goes out, suspect the sensor. If the light continues to illuminate dimly, suspect a short to power in the harness on that circuit. Further diagnostics will be required to locate the problem
Jan 13, 2016 | 1993 Chevrolet S-10
We jumped the high limit switch and now everthing stayd on except it wont stay lit
There might be a sensor in front of the burners. Looks like a metal rod. Make sure power is off and carefully use a wire brush to clean the rod. It will only have 1 wire to this sensor.
Jan 20, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
2004 Crown Vic- Headlights come on when first started and stay lit. Once driven 20 minutes and shut off; they may fail to come on or come on and then go out. Using the 'flash' wand, the high beams will...
There is a resistor in the light control module under the driver side of the dash. You can replace the whole module which is about 100+ dollars or if you're good with soldering, replace the resistor. You will need to remove the box and open it up. Find out the resistor part number and replace it. This is a common problem on the 03-05 crown vics. Good luck
Mar 03, 2010 | 2004 Ford Crown Victoria
It turns off with an error to Check Speaker wires. It's done this in the past, usual if I push the volume too it's threshold. It would always bounce back. Now it shuts down at just about it's mid-peak...
Did the fact that it was responding negatively to the loud volume not suggest it might be a bad idea to keep doing it?
The threshold on the volume knob is NOT where normal undistorted listening levels are found. Given a normal level of input you could be pushing your amp so hard that it clips or distorts and kills your speakers.
Do what it asks: check the speaker wires for shorts. Or disconnect the speakers and pray it comes back to life, then isolate the shorted (dead) speaker.
Feb 23, 2010 | Yamaha RX-V657 Receiver
My low fuel light is flashing, What does this mean? It is also very slow to indicate fuel level.
Modern bike have a two stage fuel level indicator. Flashing then solid yellow. Usually you have 5 to 10 miles when you see a flashing yellow light and about 1 mile or less when the light goes solid. Older bike had a shut-off valve and a reserve switch. You turn the switch to reserve once you bike starts to sputter or stall.
If the fuel light stay lit even after you fuel up then the sensor need replacing. That sensor in inside the gas tank.
Aug 11, 2009 | 2004 Yamaha Road Star Silverado
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Jl Audio 300/4 Car Audio Amplifier Logo
424 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
