Question about Samsung LN32A550 32 in. LCD TV
When I turn on my tv it has a dark picture for about an hour then it goes back to normal. It seems to be getting progressively worse
  • Samsung Master
  • 1,684 Answers
This a common symptom of a failing power supply. There are parts called capacitors that will start failing, when they do the power supply voltages will stabilize at the correct levels. This voltage problem causes the dark picture until they finally level out and the picture looks good until the next time you turn it off. We have an article posted on our web site that explains what the capacitors are, what to look for to repair the unit and what parts to get for the repair. Here is the link: http://www.ccl-la.com/blog/index.php/capacitors/ You can look over the other repair guides for the brands we have on the site to get an idea of what is involved in the repair. If you can solder then you should be able to do the job yourself. If you don't want to do the repair yourself we do offer a repair service, details on that can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you would like additional help on your power board you can post a few pictures and our service techs will help you trouble shoot and repair it. You can post pictures here: http://www.ccl-la.com/forum/viewforum.php?f=4&sid=b10a576721bcdf603d13ffbdf67d6e5f
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on May 14, 2010
I have a 2008, Vizio VO47L 47 in. LCD TV. When I first turn it on, the left side(facing) of the screen is dark. Not completely black just shadowy dark for over an hour. Then it goes away, It used to last...
Faulty T-con board or mainboard (AKA tuner board)...the tapping would make me believe it to be the connection of the LCD panel to the T-con board that is causing the issue! This board is located on the top of the tv while looking down from the back. Replace it and you will be good to go!
Please rate if this helped :)
Mar 08, 2011 | Vizio VO47L 47 in. LCD TV
My TV picture seems to have a "sheen" aking the
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a Samsung LN46C650 and sometimes the picture goes black and the audio cuts out for a second or two. It occurs at least once a day but it happens at random so I cannot duplicate the situation. I'm...
I have the same problem. At first the tv would just blink occassionaly and the sound would cut out just like yours. We realized if we turned the tv off then back on, it would be fine. Well, that's not working anymore, and as opposed to a blink, the tv picture is cutting off all together, can't imagine it will do anything but get worse. I called Samsung about another problem I had with the tv, the autofit screen size selectioon was great, however over time, on some channels there got to be a progressivley larger white line at the top of the screen. At first we could adjust the picture up to completely close the line. Now it is too large to cover up. Samsung said, "that's normal."....progressively worse performance?
Sep 06, 2010 | Samsung LN-T4665F 46 in. LCD Television
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
Hourglass picture. Panasonic CT-35G30T The picture is hour glassing from the sides. Starts to flicker back to normal after 1 to 2 hours. Getting progressively worse. Takes longer time to reach normal...
This is caused by bad solder connections in what's called the pincushion correction circuit. Some of the transistors get quite hot, and over time the solder connections to the TV circuit board become intermittent. When you tap the set, it causes them to make contact again so the picture is normal, but then it goes funny again. Resoldering the connections would take care of this problem. I would suggest calling a professional in to make the repair, which would cost far less than a replacement TV.
Hope this has been helpful, and thanks for using Fixya!
Feb 01, 2010 | Panasonic Televison & Video
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
My Samsung HD TV 50" progressive Monitor goes off and turns dark
Samsung HDTV will stay on when turned on the temp lamp and timer light are flashing continually. what should I do to eliminate this problem?
Dec 08, 2008 | Televison & Video
Hitachi P50H401 video goes off and on
this is from a tech tip I got that should help.
No Picture:
1. The Power Supply may not be producing the correct voltages.
2. The Digital Module (Digi-Main) may not be producing correct
turn on commands (Power 1 and 2).
3. The Logic PWB may not be supplying the correct Vs/Va turn on
commands (Vsago and Vcego).
The Panel can have a defect of two natures.
1. The panel is shorted.
2. The panel is defective, but not presenting a short.
3. Y-SUS and/or X-SUS may be defective (Shorted and or nonworking
May 01, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
Dark Picture
this problem is due to 1 not proper voltage on crt terminals 2 check video output supply voltage 3 check luminance section of chroma ic 4 if tv is very very old than there is a possibility of crt getting weak
Jul 30, 2006 | Toshiba 27A34 27" TV
Samsung LN32A550 32 in. LCD TV Logo
147 people viewed this question
Jerry Greenberg
Jerry Greenberg
