Question about Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum
Brush motor does not turn on - Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum
You could check Sears.com and click on parts then type in Model # or Part # this will get you a parts list you can choose from.
Posted on Apr 01, 2008
I have a similar problem. I disassembled the vacuum and with the belt off, the brush motor runs. But as soon as you put any load on it, it stops. I have been searching the Web trying to find somewhere that sells brush motors for these vacuums, but with no joy. I assume I need a new motor (if I can find one)? Many thanks for any help you can offer.
Posted on Mar 29, 2008
My brush is not turning and the belt is on the motor. I think the belt motor may be bad due to excessive dog hair. How do I get to the motor?
I had one melt the plastic around the bearings on the brush. you might try taking out the brush first, getting to the motor you'll have to take it completely apart.
Feb 27, 2015 | Bissell Lift-Off(R) Revolution(R) Turbo...
Why want beater bar turn on Dyson DC17?
There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
Jul 09, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Why want the beater bar turn?
Jul 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Canister vac - the motor on the cleaning head cuts out while vacuuming. does it as you draw back the head while cleaning , goes off momentarily and ten when pushed forward engages the motor again. this...
Unplug the vacuum then pull the bottom off the head and clean the brush. Check for debris on the brush and around the ends of the brush. Insure the brush moves freely. Check the motor by turning it by hand to see if it rotates freely. Check the belt to sdee if it is tight. When belts get old the will sometimes stretch and won't work properly. Hope this helps.
Jan 03, 2011 | Vacuums
Brushes are not rotating is there a belt
I had the same problem, on mine there is no belt, the brushes are driven by an air motor. My problem turned out to be one of the motor brushes was completely worn out and the motor was not turning at the proper speed.
Mar 28, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
BRUSHES WON'T GO ROUND
Try to turn the brushes by hand, while the machine is off and on it's back. If the brushes will not turn, the brush motor is burned out. If you are mechanically inclined you should not have too much trouble replacing it.
Remove the bumper, then the case. You will see a motor with a long square shaft. That will be the motor to replace.
Personally, I recommend the RobotShop for buying a replacement motor.
Aug 14, 2008 | Roomba Pro Elite Bagless Robotic Vacuum
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover U5453-900 WindTunnel Supreme Bagged Upright Vacuum Logo
100 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
