Question about Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Freezer works, fridge side not cool
MSD 2732GRQ It just seems like a lack of air flow, the frezzer fan was making noise, replaced it but still no fridge side air, all vent both top and bottom are clear
  • Maytag Master
  • 4,655 Answers
OK if the fan was replaced and the vents are open there has to be a restriction of air flow over evaporator coil causing the lack of air flow. On some models like yours there is something called an auto damper between the freezer and fresh food compartment and the damper is operated like a thermostat bulb on it's own solo. The best way to test them is to remove and place the thermostat bulb or tube coil into cold or hot water. I will gather more information for you as we go along here. Thanks, Sea Breeze
Posted on May 14, 2010
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
This is a Kitchenaid KSRS22FGBL00 - The freezer works good with a temp of -20c but the fridge side is not cold & has a temp of 8c. There is no frost build up anywhere. The air vents are not blocked. ...
Hello hlook,
I understand that you are having a problem with your side-by-side refrigerator. The Frezzer is staying closed and the fridge is not getting the air flow from the freezer in order to stay cold. The only possibility it can be is the fan. The fan may be turning but not at the rpms needed to move the air in to the fridge. As I have looked at the air flow chart for your fridge that is the only outcome I can come up with. CLICK HERE to view the air flow chart for your firdge.
With the cover off of the fan try and judge how much air is being moved by the fan. It should have pretty good air flow like the low setting on a box fan. You should be able to fell the air flow from two to three feet away.
Thank you for choosing FixYa.com
Justin
May 03, 2011 | Refrigerators
Hi we have a GBS22HCPABB fridge and the motor runs, frezzer works but fridge will not get cold just stopped
you have a few possibilities 1. a defrost problem restricting air flow from freezer to ref. 2. a bad freezer fan motor 3. a damper issue not opening to allow air to flow from freezer to frig. most all refrigerators generate the cooling from the freezer to the frig via the freezer fan motor
Mar 06, 2010 | Refrigerators
Frezzer gets cold fridge dose not compressor and fan are running fridge only cools to about 46
Most modern combination units have two fans; one under the cabinet to move air over the coils and a second concealed behind the cabinets to distribute the cold air to both compartments. When you balance them to get the desired temperatures in each, you are adjusting the air flow from the cooling coils. Typically, the freezer has the coils and the fridge gets a little via ducts in the rear wall. If this fan fails, the freezer will suffer least and that seems to be what you are experiencing.
When the compressor is running, check the inlets in the back of the refrigerator to see if you have noticeable air flow. If not, that fan has failed.
Nov 29, 2009 | GE Refrigerators
Fridge not staying cold
First make sure that ur frig.is level. Then checx the cooling coils in the back. Make sure that all the vents,frig. and frezzer, are clear. Ur moisture control could be another factor.
Sep 13, 2009 | Refrigerators
Fridge not getting cold enough, frezzer is working fine
While you hear the compressor running, check to see if there is air flow from the inside vents in the refrigerator. There is a fan that is responsible for 'stirring' the air and since the primary cooling is located in the freezer side, if the fan fails the refrigerator suffers.
Aug 23, 2009 | Frigidaire Refrigerators
Refrigerator is not working but frezzer is the fan in the freezer is working, could the problem be with the thermostat.
The cooling in the fridge comes from the freezer side via a damper, make sure there is nothing obstructing the damper and that air can flow freely into the refrigerator side.
Mar 05, 2009 | Frigidaire FRT22RGC
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
