Question about GoVideo Go Video DVD/VCR Combo
Initializing DVD My GoVideo Combo (VR 3845)won't recognize any blank DVD to initialize it. I have used several blank DVD+R discs and it just spins and does not ask me to initialize it. It eventually ejects the disc and says it can't read the disc. I can record onto and already initialized disc and I can record to a video tape but the intialization of a new disc is not possible. Any ideas?
    Master:
  • 377 Answers
If you know you're using a readable disc, clearly the drive is the source of the problem. It's possible that the drive's laser has become dirty to the point that it can't read the disc. Open the drive's caddy and spray into the drive with compressed air. The blast of air should blow away any dust buildup over the laser. Pop a disc into the drive and try to read it again.
Posted on Apr 14, 2008
  • Anonymous Apr 14, 2008
    If your drive still can't read any disc, even after you clean it, the drive may have a serious problem indeed. The drive's motor may not be working properly, or the laser in the read head assembly may be malfunctioning.
    Enjoy..
  • 3,037 Answers
1. Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
2. Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
3. Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
4. Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
5. Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
Let me know if this doesn't work and we can try other options to get it working.
Thank you for using Fixya and Good luck.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 15, 2008
    blowing compressed air into the device could damage the device, please be careful if you try that like was suggested by another expert
  • Benjamin Patri
    Please let us know if you need any further help and we would be glad to do what we can to solve this problem
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    Were you able to get this working, if not please let me know otherwise I would appreciate it very much if you could rate this solution
    Thank you
    Genius:
  • 1,665 Answers
Try to clean lens eye wth a specific cleaner, and try again
SOURCE:
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Firmware Update
I have the GoVideo upgrade for the VR 3845 Combo on a disc. Email me at [email protected] for instructions on how you can get a copy.
LSpeh
Mar 18, 2008 | GoVideo Go Video DVD/VCR Combo
Recording
The device defaults to initializing discs to DVD-VR format. I believe this is incompatible for all devices except other DVD recorders. You need to reinitialize the disc to DVD-R format from the menu. These should then work in other players.
Mar 12, 2008 | Samsung DVDR120 DVD Recorder
Initalizing DVD-Rs
are you using a quality brand of dvd-r like memorex.
Also after making a recording you must finalize the disc you recorded so it will play on other players.
Jan 08, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
Go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Dec 25, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
GoVideo VR3845
I too have this problem, will read regular CDs but no DVDs. I get the sme message, then the disc ejects. Is there a RESET function?
Jun 30, 2007 | GoVideo VR3845 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
192 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Ekse
Demonic-2011
Demonic-2011
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
