Question about Dynex DX-LCD37 TV
The menu box keeps coming up on the TV screen. What can I do to stop this from happening?
    President:
  • Dynex Master
  • 749 Answers
Change the little panel with buttons on the side - you'll likely find it on eBay.
Posted on May 14, 2010
How do i remove the 4 boxes that keep coming up at the lower left of the screen?
  1. go to main menu -
  2. select display -
  3. select advanced at the bottom of this screen -
  4. in this menu you can turn on/off the trumotion demo.
May 22, 2016 | LG 42LG50 42 in. LCD HDTV
Why does menu keeps poping up non-stop when watching tv but when sky box is paused this does not happen, why????
Can you use a digital camera to view your remote to see if it is sending out signals when it should not? It might have dirty buttons from food or other dirt. This can cause it to send signals even when the buttons are not being pressed.
May 11, 2014 | AOC Televison & Video
BRAND NEW JUST TOOK OUT OF BOX VIZIO E320VL 32 INCH FLAT SCREEN TV Menu constantly pops up and flips endlessly through the choices. Ignores you when you try to enter a selection and move back to what...
I would not keep a new LCD TV that has immediate problems. I would get a refund and purchase a more standard brand television. Experience has taught me that if one has problems immediately with an LCD TV itself, it is likely to continue to be problematic.
Thank you for using FixYa.
Dec 26, 2010 | Vizio VW32L 32 in. LCD HDTV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Menu box keeps appearing on the screen
There are meny reasons this might be happening. here are a few obvious ones.
1. The remote is under a cushion and buttons are being pushed.
2. The Sensor on the set is in the sun and the sun is confusing it.
3. You neighbor is messing with you
4. The set has a bad chip/loose connection/etc.
[you might try something as simple as unplugging it for a minute.]
5. it's set to 'DEMO' mode.
Ken
Jan 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Problem with black box appearing on tv screen
Check to see if close caption is enabled, on remote, press menu, see if there is setting.
Jul 26, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
P52151WK 52" projection TV, no video
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Aug 26, 2007 | Televison & Video
Dynex DX-LCD37 TV Logo
172 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
