Question about Maytag PYE2200 Dryer
Heater stopped working - Maytag PYE2200 Dryer
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please rate me, Thank you
Posted on May 14, 2010
Over heating and heater stop working
If heater runs cold.no water in it so could be low on coolant.could be a water pump issue.could be air locked in heater.good luck.
May 26, 2014 | 2000 Chevrolet Blazer
Honda pilot heater stopped wprking after battery replaced
I would agree with Honda. Why would replacing a battery ruin a heater?
Mar 26, 2014 | 2006 Honda Pilot
Wall heater stopped working pilot won't relight
Are you out of gas? If it was running and just stopped and the pilot won't light when your pushing the pilot knob, you may have ran out of gas
Dec 06, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
Got a problem with the cars heater .i've changed the thermostat flushed out system.some times it acts like it wants to work but most of the time it dont get warm. thought it might be the heater core but...
Sometimes the heater core get stopped up, especially if someone used stop leak in the cooling system. If the heater core stops up then you wont hardly get any heat. There are possibility's to like if the air doors and actuators under the dash, or the heater controls themselves act up. I would pull the two heater core hoses off under the hood and see if water will flow through the heater core. A water hose is good to use for this. If it is stopped up you wont get much flow. If being stopped up turns up to be your problem, then the heater core will have to be replaced to make the heater work like it should.
Dec 21, 2010 | 2000 Chevrolet Camaro
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
I have a 92 mazda mx3 that i just replaced my water pump on and we thought my radiator was leaking so we put radiator stop leak in and right after that my heater stopped working the heater was working fine...
the stop leak has clogged your heater core. you may be able to flush it out if there is still some flow, otherwise heater core will need to come out.
Jan 02, 2010 | 1992 Mazda MX-3
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
1997 GMC Jimmy - Heater Problem
the heater stops working then as you are driving the heater might start working. it comes on when it wants to it was working all summer it seems to stop working in the winter.when it strts getting cold outside that is when it starts acting up.
Nov 16, 2008 | 1997 GMC Jimmy
Dryers Logo
76 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
