Question about Brother Sewing Machines
It will not run. I was sewing and it made a noise
It will not run. I was sewing and it made a noise inside the "wheel" and not it will not run.
  • 36 Answers
If the achine will not turn, check to see if there is a piece of thread jamming the shuttle.
Posted on Jun 02, 2010
Kenmore sewing machine my sewing machine won't sew, it just makes a noise
If it's an older mechanical machine, it most likely has seized due to lack of recent, thorough oiling. Refrain from forcing the machine to run as it could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
Aug 10, 2017 | Kenmore Sewing Machines
Sears Kenmore Sewing Machine (old one)
It might just need a very good cleaning on the inside- you said it is an old machine - is the motor located on the outside of the machine? I. Some of the older machines a lubricant is used
and it comes in a tube - check the manual on this Find a
good generic repair man - good luck
Jan 29, 2015 | Kenmore 15218 Mechanical Sewing Machine
KENMORE 15612 MAKES SCREAMING SOUND WHEN RUN.
could possibly be that your wheel belt it to tight. Possibly you need to oil the stitching arm and other areas their should be small holes on sewing base and one on top beside the where the sewing arm is located
Jan 11, 2015 | Kenmore Sewing Machines
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
The hand wheel will not move when I tighten the smaller wheel - I oiled everything and still nothing!
when a sewing machine start making noises, it's time to have the
machine checked, just like you would a car.
Jun 05, 2012 | White Sewing 1766 Mechanical Sewing...
Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
Apr 18, 2009 | Kenmore 16622 Mechanical Sewing Machine
Singer sewiing machine clicking
Remove the needle , tighten the needle set screw so the clamp doesn't rattle and run the machine.This will give you a better idea of where the noise originates.
Remove the top cover and put a drop of sewing machine oil(not 3 in 1 oil) on anyplace that moves and rubs. Run the machine again and see if you still have the noise. Replace the top cover.
Open the side cover(left side) put a drop of oil on any thing that moves or rubs(Shafts or joints). Run the machine again.
Remove the bottom cover and repeat the above processes.
If you still have the problem and it is bothering either you or the machine then it needs to be seen by a technician.
sewman7
Jul 10, 2008 | Yamata FY2600
Sewing Machines Logo
54 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
