Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
When I print a picture even using epson photo paper I am getting lines on the photos now. Is there anything I can do to fix that?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 14, 2010
I have Epson stylus TX121 printer but whenever i m using to print out photo, photo comes in orange and red color, pls help me ....
Hi
When switching from printing on standard paper to photo paper, you need the change the paper and picture quality settings in Printing Preferences.
Start > (Control Panel) Printer(s) > right click on the Epson TX121 printer icon > Printing Preferences > Main > tick Photo or Best Photo > under Paper Options/Type select the closest match to the type of Photo Paper you are using (see photo paper packet for guidance) > Apply > OK.
Use the same procedure to switch back to standard paper settings to print on normal paper again.
I hope this helps
Aug 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I am printing a collage of photos on cardstock (for a calendar) using an Epsom Artisan 810. White vertical lines appear evenly spaced along the landscape format. My wife says it is due to the poor...
When you print photos, in Preferences you have to set up the quality of the print to either Best or Photo whichever is the highest one in the list. Hopefully this will increase the quality of the printing, although this is not a photo printer. And you are correct, it's a printer problem.
Nov 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When printing photos especially A4 size my printer leaves white dotted lines across the photo
This is caused by the paper feed wheels (small spiked metal wheels to draw the paper through the printer.) Unfortunately, there is no way I know of to fix this, but you could try using different types of photo paper.
Aug 15, 2010 | Epson Stylus Photo R300 InkJet Printer
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
How do i enter the photo paper so it prints off pictures
Maybe the printer has a sensor that detects that the type of paper you enter is not compatiable. Check your documentation as to what type of paper "picture" you can or should use less you spoil your printer.
Aug 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
