Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Remote control problems
We've changed the battery in the remote control, but the fan doesn't respond. Can't change speed, and there's no light either up or down. Originally thought the bulbs may have blown, but why is he fan speed button not working? Help!
    President:
  • 1,871 Answers
Hello :
The problem here is not with bulbs neither the remote but it must with the PCB [ printed circuit board ] inside the fan .. for more information please check this link .
I hope this will help .
PLEASE RATE !
Posted on May 14, 2010
Why does fan no longer respond to remote?
Remote controlled ceiling fans do not respond favorably to wall switches. To restore order, you will have to start over. Shut down fan power at the source. Set the wall switch to ON and promise to never, ever use it again. Turn on power at the source. Try remote fan and light control functions. If either does not work, there could be pull-chain switches on the fixture that are interfering. Troubleshoot to get both fan and lights controlled only by the remote.
Mar 30, 2016 | Dryers
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
RCA Home Theater RT2906 doesn't respond to Remote
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Ceiling fan
remote only problem! use assemble remote and test in fan!
Jun 29, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Dec 08, 2007 | Universal Remote Control Hampton Bay...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
241 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
