Question about Weber Genesis Silver B Grill
Middle burner looks ok but has huge yellow flame
I bought a used genesis three burner. The outside burners burn with a nice blue flame, but the center burner burns tall and yellow. The center burner has been replaced, as it looks much newer than the outside burners. I purchased a new burner set, but I am not sure the burner is the problem. The center burner holes were on the bottom, so I turned it over so the holes were on top, and that didn't help. I tried adjusting the air intakes, and that made little difference. I suspect the previous owner had this problem and tried to fix it by replacing the middle burner. This apparently didn't fix it, so he gave it to the Salvation Army where I bought it. What should I do next? Do need a new manifold? Can a fix the center valve?
  • 494 Answers
Sounds to me like the new burner that was put on, has the wrong gas orifice in it. Possibly a nat gas orifice instead of a propane orifice. If it's a propane grill, take it to your local propane co and have them look at it. Also, sometimes just a spiderweb or dirt dobber nest in the burner's venturi tube can cause that kind of problem. Blow it out with an air compressor and see if that's the problem.
Posted on May 15, 2010
I have a Gibson gas furnace model gl1ra072c12a, the middle two burners flame are blue both end burners are yellow . All were cleaned. as well as jets what could be the problem?
If the flames are yellow AND lazy, not acting like the two blue flames are, the problem sounds like excess carbon build up within the heat exchanger ABOVE the two yellow burning burners. If that is the case, the yellow burning flames are contributing additionally to the carbon already in there. Eventually, the lazy flames will roll out into the furnace vistibule and possibly burn wiring creating a major problem. There are looooong wire handled bristle brushes 30" long that must be used to thoroughly clean the heat exchanger after the burners have been removed. A shop vac will help greatly in reducing the nasty carbon mess.
Usually, the vent collector hood and flue is removed to brush down from the top and up from the bottom alternately. If there are air shutters on the burners, make sure they haven't been throttled too far down limiting the combustion air causing the original problem.
You need a certified HVAC service tech to look at this issue.
Dec 09, 2014 | Heating & Cooling
SOOT PROBLEM CAUSED BY YELLOW FLAME
If they burn yellow then they are blocked IE lack of air causing flame to burn floopy yellow hence soot , clean burners and orfices to burners .
Mar 25, 2012 | Grilling
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
What color should the burner flame be
The burner flame should be blue.
If you have the spider air flow open to wide the flames will be yellow.
This means the gas flow has to much oxygen.
Typically the air vent should nearly closed.
You may not be able to remove all the yellow and have a few Yellow tips.
This is ok, just try to adjust were you have the last amount of yellow in the flames.
Hope this helps.
Jul 18, 2010 | Weber Genesis Silver B Grill
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
My grill does not exceed 300 degrees. The rear burner is barely lit, it sputters with a blue flame. The Front and middle burners run well, blue flame no yellow. I changed the regulator with one from home...
Bypass valve need reset. All grills made after 1996 have this valve.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait 90 seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and a rep walk me through it.
Jul 08, 2009 | Weber Genesis E-310 Gas Grill
No blue flames
Sounds like the burners have worn out. Replace them.
Mar 07, 2008 | Kenmore 16225 Grill
Weber Genesis Silver B Grill Logo
411 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
