Question about ASUS K8S-MX Motherboard
Booting up on switching on my computer, it goes through the boot sequence then stops at a blank screen with a flashing cursor in the top left hand corner,when i press control/alt/delete it boots up ok. is there an easy solution to this annoying problem.thank you in anticipation
  • 00100mike101 Oct 04, 2008
    same problem im running a new sata drive for xp also tried 2000 no luck same problem and the hd is primary boot also tried cd boot 1st hd 2nd anyway could this be due to running 32 bit not 64 bit win what bios settings are different for setting up a 32 bit system
    Genius:
  • 1,019 Answers
the system is looking for a certain file or a command prompt.
1:) try re-installing your operating system, this will overwrite any corrupt or deleted files. ** backup important data first**
Although you should get the option to:- leave existing file system intact.
2:) if this is a recent problem, you could restore the computer ( windows XP ) to an earlier date. before the problem occured.
3:) enter the bios to ensure the computer is booting from HDD first.
Hope this helps.
Mike @ compurepair.
Posted on Mar 29, 2008
SOURCE:
Pc wont boot
You didn't post the Make, Model of the computer. Do a System Restore/recovery.
Feb 23, 2013 | Computers & Internet
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Does not boot.
your laptop is not booting either it is os crash or hard drive not detecting try to go to safe mode .
Nov 11, 2012 | Acer Computer Aspire M3 Minitower Desktop...
Nothing comes up on the monitor
Please check if there is power to the system.
Is this a laptop or desktop?
If it's laptop see if any light turns on in the computer and or if you can connect it to an external monitor to check if the problem is the LCD display or the Video Graphics Adapter.
If it's a desktop see if there's power to the monitor and to the system.
Do you seea any message like no signal or output out of range or is the monitor totally blank?
If you can provide additional information like if it's a desktop or a laptop, when was the last time it worked if there are any indicator of power coming to the system.
Hope to hear from you soon.
Aug 07, 2011 | Computers & Internet
Hi When I boot it up , the acer emblem comes up then the screen goes black with a small cursor flashing in the top left hand corner
If you are having just a blingking cursor on boot up you must check if there is a disc inside the disc tray, or kindly check as well if there is a USB flash drive plug in on your computer and if there is any please remove them while your computer boots up as your computer might boot from it and it may cause just blingking cursor.
If there is no disc or USB flash drive installed, what you can try is to boot your computer in safemode and perform a system restore. Atleast restore back your computer 2 to 3 days back before this problem happen.
To perform safemode:
- turn off computer
- press the power the botton and after 2 sec tap F8 repeteadly until you see all the safemode options
- select safemode with networking/safemode use the arrow keys to highlight it then press enter
- computer will automatically boot into safemode desktop.
To perform system restore:
- click start > all programs > accessories > system tools > system restore
- click next then select desired date then follow the on screen instructions
- once system restore is done it will automatically restart and boot your computer in normal mode.
Cheers . . .
Mar 14, 2011 | Acer Aspire 5920-6727 Notebook
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
Apr 05, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
My gateway e6100 cant boot from a flash drive it flashes at the balck screen with the cursor in the top letf corner then goes to normal boot sequence
u need to change the preferences for booting technique....when u start your PC try to enter into BIOS settings.....change the boot give first preference to USB....and save it may try to boot from USB
Mar 04, 2010 | Gateway E-6100-C PC Desktop
My windows xp stops booting
Is the monitor blank or is there a blinking cursor in the top left hand corner.
Feb 01, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
ASUS K8S-MX Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
