Question about Edirol UA-4FX External Sound System
Edirol UA-4FX : No Midi output sound: OK with 1/4 plug audio/guitar in
It's wierd. Everything works except the midi. I can use the same Casio CTK-519 and send the sound in through a regular 1/4 inch audio cable, and capture it as if it were a guitar in the guitar intput. And I can hear that and record and playback that. But when I put in the midi cables, nothing. The monitor on the laptop blinks, so, it knows the midi information is making it through the edirol into the computer. But when I record, no sound.
It must be something about the settings. Obviously this is right out of the box, so, maybe someone will be able to tell me what settings I need on the edirol (right now, it's set on analog, and 44.1 and advanced. ) Now, is there something about my settings in sonar le? Or, is this keyboard too old?
  • Jazzjunkysue Mar 29, 2008
    Me, again. now, I got a little further. I set it to digital and opened the new project as midi only and finally got the right dialog box to set the patch. I can now see the notes I play in the piano roll, and the regular screen (whatever you callit.) But I still can't hear it. I can see it but not hear it. So it's definitely my playback settings. Yes, the input and output for that track are the edirol. And other things (imported tunes and guitar input) can be heard through the system, just not the midi.
    So, I'll be someone knows what setting I need to change on the Sonar LE so that I can hear the midi.
  • sben May 11, 2010
    Are you using SONAR LE? Have you installed a softsynth? I recently bought the same device and it came bundled with SONAR LE, and have been working through the many hurdles to get everything up and running. If you are using SONAR LE go to view>synthrack>+ and pick a soft synth. Then you have to assign every track to a soft synth: pick a blue (midi) track and expand its window, then select midi output (on the little bar on the left) and select one of the synths listed there. I am also very new at this, so don't expect much. It worked for me though, although the sounds are still horrible. Good luck.
Using the Edirol UA 4FX I have the same problem unfortunately, with both Reaper and Sonar 7: the data I play - which I can't hear when I play it - is getting recorded by the software, but won't play back. In both programmes I have the option of inserting a soft synth track, and that allows me to play, record and hear, but only sounds that are produced by the soft synth - the usual options - which I suppose is some sort of solution, but it means that I can't take advantage of any of the quality sounds or the arpeggiator etc on my 2 week old Juno D LE. It's now up for sale (£290) and I'm going back to my old Yamaha PSR295. The latest driver for the Edirol supports ASIO btw. It can be downloaded from Roland's site.
A workable solution is to purchase a copy of Mixcraft 4. I've tried the demo and it works fine - no, can't afford it.
Posted on Nov 04, 2008
He's wrong you need to change your wdm driver to asio 4 all!
Posted on Jul 31, 2008
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Nov 19, 2008 | Edirol UA-4FX External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
No sound out from input
It's probably your computer, more specifically the type of application you're running it on/in. Also, when you install or fiddle with the settings, you have to be careful because it can be so confusing fixinfg them.
Dec 12, 2007 | Edirol UA-4FX External Sound System
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
Apr 30, 2007 | Edirol UA-4FX External Sound System
No MIDI
make sure you have the last windows updates, i know there is a tid on microsoft for that.
Dec 10, 2006 | Edirol UA-4FX External Sound System
Midi OUT has "holes"
Midi out on your soundcard to midi in on your keyboard. Midi out on your keybaord to midi in on your soundcard It's a lot to do with audio drivers,asio drivers are a lot better than standard realtec drivers. A lot depends on your cpu memory etc,midi sends more than just one note at a time I can play all ten fingers on midi and that's with really powerful virtual synths. Cpu memory drivers all effect audio and midi
Sep 17, 2006 | Edirol UA-4FX External Sound System
Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Aug 29, 2006 | Edirol UA-4FX External Sound System
Edirol UA-4FX External Sound System Logo
800 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
