Question about Coleman Electrical Supplies
Coleman Powermate 1000 Starts fine then revs up and dies
I have a model # PM301010 Coleman Powermate that will start up then after a minute of idling it will rev up then idle down. As it tries to rev up a second time, it dies. This happens with or without a load.
When the covers are off and watching the side of the carburetor you can see the throttle stop move far open (as it revs up) then close as it idles back down, then when it dies you can see the carb open back up again. Upon startup it will rev high then immediately die.
Once, when it was about to rev the throttle stop was held in place and it continued to idle fine.
    New Friend:
Hi, I just pulled out my Coleman Generator (1000) and it actually started then died. Has been sitting for about 10 months. I ran it out of fuel before putting away. Anyways, it starts for a minute than dies. If I press fuel primer it keeps running but than it dies. So, I took the cover off, the one towards exhaust side and was able to see carburetor. There are two screws with springs on them. I guess these screws control fuel and air for carburetor(you can clearly see they are on carb). As stated above there are not many adjustments. There is no choke for the model I have; just an on and off switch and fuel prime button. The instructions say fuel it up (with the right oil/petrol mix of coarse), switch it to "on", prime it, pull starter cord and then that's it......"not happening". Okay, so I took my little flat head screwdriver and backed out each screw while counting how many times I turned, until I was able to remove completely(PLEASE remove one at a time and take note which one went where AND how many times you backed out). Take a can of carb cleaner with the straw and shoot through the holes where the screws came out of. I shot carb cleaner a couple pumps in each hole. Examine each of screws removed as these have pointed ends(replace if damaged). Put screws back; again make sure you count how many turns. This worked for me. Idles perfect. Thanks!
Posted on Oct 24, 2015
SOURCE: generator fuel-oil mixture
My manual for my Powermate 1000 says 18:1 fuel mixture.
Posted on Sep 13, 2008
CarlGehrke
  • 169 Answers
SOURCE: Idle fluctuates up and down
This sounds like a carb problem. While there are not adjustments on the carburetor other than the idle stop screw, you can still disassemble the carb and clean it out. For what it's worth the flapper thing at the engine side of the carb is the throttle, that other flappy thing at the air cleaner side of the carb is the choke. :-)
Modern day small gas engines like this have really small holes in the carb compared to the good old days. You should carefully look in the fuel tank for any junk and dirt that may have sneaked in there (blow it out with air), also look at the fuel line and if it's not soft and nice replace it. Lastly be sure to poke a thin wire thru all of the holes in the carb when you're cleaning it, dirt hides everywhere.
Rate me please,
Carl
Posted on Dec 03, 2008
SOURCE: Automatic Engine Idle Control
RPM of the motor and the voltage hertz output of the alternator are directly connected. In this case the motor speed must be set on correct alternator output and locked on that speed. (Star & run on the spicific speed). Normally it would be 1 800 RPM = 110 volts = 60Hz, OR there are in some cases that RPM will be doubled that. It all depends on the make of the unit.
Posted on Feb 11, 2009
  • 47 Answers
SOURCE: generac 4000XL. engine dies when idle control switch is thrown.
there is some problem in your AMF/ATS pannel
Posted on Sep 22, 2009
protek480
  • 1723 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Tecumseh model 100 engine 10hp on a coleman powermate generator it starts ok however after about 3 minutes the engine sputters like it is running out of gas and quits.
check the fuel mixture settings i believe main screw is 1 3/4 turns from closed and the idle screw is set at 1 1/4 turns from closed. These settings are for non OHV models. also check that if you have a fuel filter installed that it is not plugged up.
Sep 27, 2009 | Coleman Electrical Supplies
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
May 22, 2009 | Coleman Powermate Premium Plus 6250W...
Engine missing
Get a DMM that can measure frequency (Hz), then check that with no load and the idle control set to off the frequency is 61.5 Hz - If it isn't you have to troubleshoot why it isn't and correct it.
You should also check the idle control mechanism if there is one on the generator, with it on the generator should start up at regular speed, then slow to idle speed, then rev back up to regular speed when you draw current from the generator. To check it use the DMM to measure the speed at startup ( should be 61.5 Hz), when it idles down (about 37 Hz), when you're drawing power from any other outlet ( pretty close to 60 Hz). If the generator has idled down and you shut off the idle control it should rev back up immediately.
Please rank my solution,
Carl
Oct 03, 2008 | Coleman Powermate Premium Plus 6250W...
Generator
I had same problem, oil sensor was reading low oil and it was full.Have sensor changed
Electrical Supplies Logo
574 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
