Question about Delphi SKYFi3 XM Radio Receiver
My Skyfi3 device will not turn on. Depressing both the Mode and volume button simultaneously allows it to come on briefly, but it as soon as I release either button, it goes off and will not come back on.
    President:
  • 1,070 Answers
  • Attach all connection Firmly and Securely
  • Ensure cigarette lighter adapter /Auxiliary power adapter is Clean and free of corrosion
  • Check the adapter Fuse by unscrewing the end of the Adapter
  • If required Replace it with 2-Amp fuse only
Sometimes your Battery may be Low.Check it and Change.
  • Press power and vol. keys then while holding them down plug in power and hold keys 30 to 45 seconds to give it time to acknowledge the power.
  • For Using Guide Click here
For More Technical Support & Customer Service: For help with technical questions, contact Delphi at 1.877.GO.DELPHI (1.877.463.3574). Our Hours: Monday-Friday, 8:30am - 5:00pm Eastern Standard TimeSaturday & Sunday: Closed
To Email Click
Hope this make you better..Thanks for Contacting FixYa...
Posted on May 14, 2010
Bypass a forgotten lock code
Make sure the tablet has been turned off first by holding down the power button until you get the power off dialog box and choose power off. Then hold down the volume button and while continuing to hold the volume button, hold down the power button until you get a message like 'booting into recovery mode' or a dialog box that allows you to go into recovery mode and do a factory reset. Some tablets may boot into a screen with the Android robot on it that you can touch the robot and get to the recovery mode screen. When you do a factory reset, all user information stored on the tablet will be cleared, including the passwords or lock codes.
Jan 05, 2015 | Chromo Inc Vuru T2 7" Android JellyBean...
I have repeatedly used the standard reboot for Skyfi3 and it will not work. There is supposed to be another high reboot that can be done.. Does anyone know it? Tyhe unit will not get out of scanning media...
I downloaded the updated firmware, saved it to my computer. Hooked up the skyfi3 to the usb port and took the power cord from the home dock and plugged it directly in to the unit. Held down the volume up and mode button, then as soon as it got to the "scanning media" screen I hit the up arrow, then the down arrow, then the up arrow again. This got the unit running and I was able to upgrade the firmware. It took two or three times to work, but eventually worked like a charm.
Dec 17, 2010 | Delphi SKYFi3 XM Radio Receiver
My Delphi skyfi3 xm radio has stopped working, It seems to be in a freeze mode with the channel and signal strenth showing good but I am unable to command it to change. I have tried holding down the...
Hi
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 20, 2010 | Delphi SKYFi3 XM Radio Receiver
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
My SkyFi R 1.18 does the same thing but the solution here doesn't
If it freezes, you have to push the volume UP button and Power button to 'reset' the unit.
go to the XM website and get the latest FIRMWARE update for the SkyFi3 and download that. Also, you CANNOT use an SD card larger than 2GB or you'll have problems too. So first, upload the new firmware (using the AC adapter plugged directly into the bottom of the radio) and the cable that they gave you to hook up to your computer and do the firmware update. Delphi customer service can walk you through this too. Good luck, you'll get it pretty soon.
Aug 08, 2009 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi 3 freezes up.
What you need to do is simultaneously hold the VOLUME UP button as well as the MODE button. This will reset the unit. From what I read of your problem, you were simply holding the VOLUME plus MODE buttons.
Jan 29, 2009 | Delphi SKYFi3 XM Radio Receiver
My xm skyfi3 is on and the buttons will not work It is frozen up and I cannot get it to turn off or do anything. I have checked the button lock switch and it is off
Try this: "Reset your SKYFi3 by pressing and holding the volume button and pressing the mode button" (from user guide page 62)
Dec 13, 2008 | Delphi SKYFi3 XM Radio Receiver
Screen locked on "Checking media"
When the radio locks up on the Checking Media page you hold the + button to the volume and the MODE button wait for 3 seconds and it will turn off...  Thanks to Delphi for this assistance!!  Chris K.
Jun 02, 2008 | Delphi SKYFi3 XM Radio Receiver
Trying to update firmward on Delphi SKYFi3.
when it gets stuck scanning. Press (volume up) and the (mode) button both down for a few seconds. when you release the two buttons this will turn it off and back on in few seconds.
Mar 20, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 XM Radio Receiver Logo
332 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
