I have a Biz Hub 250C Copy machine--- I can not get it to print from microsoft word in COLOR----I can not find any settings to change????? It only prints in Black and White from word ---- same for trying to print photos downloaded on my computer
  • victoria cooke May 14, 2010
    the machine is a Konica Minolta Biz HUB C 250 and it prints beautiful color. It just won't sink to color when I input from my laptop
    DELL operating system --- microsoft apps!
  • 12,061 Answers
Http://www.konicaminolta.com/hk/eng/business/support/manual/pdf/C203_253_353.pdf
filedb.experts-exchange.com/.../125026/AD-NDS-SMB-20userauthentication-.pdf manuals above.
Select PROPERTIES
Often under the main tab, or under quality you might need to choose to print in color.
OR, you need to possibly install the latest drivers available for your operating system, and all Word & Windows updates are done as well. As really, it must be a driver issue, as it is the driver, that interprets , the data from word, and passes it on, to the printer, now in a generic driver, it simply strips all formatting regarding color etc, from the data sent, and passes the simple data on to the printer, now, in a Proper driver, all these "Bells and whistles" so to speak are activated. Then all sorts of options may be enabled. So after you set it up, ensure you go into properties before you print and check, that print in color is checked, and not B/W or greyscale.
Posted on May 14, 2010
    President:
  • 1,469 Answers
it all depends on the copy machine. When you bought the copy machine did you buy the one that can print color printing?, cause some of the copy machine those not have the ability to print papers or pictures in coloured form.
First of all check if the printer has Color copy machine written on the body and you have a Copy paper Color ink cartridges.
If it has this written on it,, and you have a copy ink cartridge, then i will give you the procedure on how to print with it.
A color copy machine can make any document more vivid and bold, especially if charts and diagrams are included. Using a color copier is similar to using a traditional black-and-white copier. When making multiple copies, it's important to make sure that there is enough ink in the machine so the copies will be bright and colorful.
Place the document you want to copy face down on the glass surface of the copy machine.
Make a test copy to determine if there is enough ink to produce crisp, clean copies. If colors seem faded or choppy, it may be time to change ink cartridges.
Select the number of copies you want to make. Adjust color settings to achieve the desired result.
Press 'copy' or 'print' depending on the model of copy machine you own to begin making copies. If making copies of multiple pages, copy the desired amount of each page and then switch pages until all pages have been copied.
Check each copy to ensure that all pages are legible.
Tips and warnings.
  • Keep extra color ink cartridges on hand so you can change them when needed.
  • If color copies are still faded or dull after changing the ink cartridge, contact the manufacturer or copy-machine technician, as there may be an internal issue.
Hope it helps.
Take care.
    of course it is a color machine !!!!! My color is not synchronizing when I input from my laptop computer
    which is a dell --- Vista Op ----- I am using microsoft word ------------the machine is a Konica minolta --- BIZ HUB CCCCCCC (which means COLOR) 250!!!!!
  • Egwe Emmanuel Onyedikachi
    Hi, you can check the color ink if it is finished, replace with another and start printing again. Or you can reset the printer to default and try it out again.
    Take care.
Why the test page "demo page " in biz hub c454e out black and white not color
Your default is set to black and white and not color, reset to default will do and will reset all setting!!!!!!!!!!
Jan 30, 2018 | Konica Minolta bizhub Office Equipment &...
How do i get my mg6350 to work with ubuntu 14.04
http://printersquestions.com/How-to-install-Canon-PIXMA-MG6350-on-Ubuntu.html
if it doesn't work you may be able to use ndis wrapper
http://www.cyberciti.biz/faq/linux-ndiswrapper-wpa_supplicant-howto/
Jan 03, 2015 | Canon PIXMA MG6350 Inkjet Multifunction...
Biz Hub C252 is printing dark
The machine probably needs a service and the gradations needs to be set.
Sep 27, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
When copying the machine is printing out 7 copies, I put in 01 copies and it will print 1 copy but returns back to 07 copies. how do I get the machine to stay at 01 copies, thank you Keith Bell
Tha machine seems to default back to a setting within and so it needs to be reset. Please remove the power for few hours and allow the machine to reset. If the settings change the processor would have reset.
if not there is a possible error in the memory . Please check the manual as you have failed to give the make/model of the machine.
Jun 10, 2011 | Office Equipment & Supplies
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
27 people viewed this question
k24674
jasbo
jasbo
