Question about Invacare Pronto M51 Power Wheelchair
Sudden jerks to right
It wants to turn to right especially when going uphill or uneven surface.
  • 278 Answers
Sounds like you've got one motor which is beginning to fail or your joystick gimbal is out of alignment. A bad joystick gimbal will give a joystick out of neutral fault at start-up. A weak motor will give you the sympton you describe. A bad or non-freewheeling caster will give a similar symptom.
Posted on Oct 24, 2010
2007 dodge caliber. started jerking especially going uphill. service engine light stays on although no codes show up. any clues?
read the fault codes to determine what put the engine light on
regardless there will be codes and it just takes an experienced technician with the right connections to read them
next check the cat converter as it may be failed and blocking the exhaust system
May 10, 2017 | Dodge Caliber Cars & Trucks
How will I know if 1 of the engin mountings broke or collapsed
If the car only swerves briefly it is probably an engine mounting but if the car keeps steering to one side with constant power, the problem could be suspension related.
Another sign of a faulty engine mounting is when the car vibrates from side to side under a certain constant power load, usually very low power like on a slight downhill. Accelerating ******* an uneven road surface with faulty engine mountings can result in a "stop-and-jump" feeling of the vehicle.
The best way might be to open the bonnet and with the brakes applied. let someone put power on first gear and next, on reverse. Check how much the engine moves. The engine should never pull to one side, but only upwards or downwards. In your case, the car pulled to the right when the engine braked the wheels. That means the engine will pull to the right of the car when the power is applied in reverse, if the engine mounting is faulty.
Apr 21, 2016 | Cars & Trucks
Car jerks going uphill
Maybe! Check your air filter, also go by auto zone, or O'Reilly Auto Parts, have them to check the engine code, it's free! Could be a bad oxygen flow sensor, or other sensor causing this! and you really need to fix that leak. hope this helps!
Apr 02, 2016 | Cars & Trucks
My car jerks and seem to lose power especially when driving uphill. car sputters like its going to die. What is causing this?
Check your plugs and wires first and get back to me. Give me more information such as miles and latest maintenance performed on it.
May 22, 2015 | 2001 Mitsubishi Galant
2004 dodge dakota clubcab jerking while going up hill
Check the help links mentioned below:---
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Jerks and Hesitates During Acceleration?
http://technoanswers.blogspot.in/2012/07/2004-dodge-town-country-jerks-and.html
These details will help.
Thanks.
Dec 09, 2012 | 1999 Dodge Dakota
96 escort 1.9 manual jerking while accelerating 96 escort 1.9 manual
best advice is dont go 40mph in 5th gear... if you are going up a hill at 40mph in 5th gear i have no doubt that it is jerking, your putting too much stress on the engine. shift up to 4th or 3rd you will be fine. 5th gear is an overdrive gear. 55+mph
Dec 01, 2011 | Ford Escort Cars & Trucks
Clutch slipping?????
yeah it could be full of water in the gas you bought. see if you can pull a sample and check. start looking at the filters.
Mar 21, 2009 | 1996 Chevrolet Cavalier
Front end shake 90 toyota 4runner 4x4
it sound's like to me it is your IDLER ARM chek your arm on right side for slack if it has up and down motion if so thin it is time to change it
Oct 27, 2008 | 1990 Toyota 4Runner
Invacare Pronto M51 Power Wheelchair Logo
77 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
