Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black
Oven ignites for a few seconds and stops heating
Sometimes the oven comes on fine and other times it will come on and then seconds later turn off !
  • Whirlpool Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 14, 2010
I have a westinghouse 476 gas oven, the oven does not turn on all the time the ignitor heats up but no gas comes out. when i take the cover off the ignitor and tap on base of oven it ignites and works...
It sound like you have a valve problem some types of ignitors have a heat release valve, by hitting it you cause this to release, I would suddjest replacing the ignitor unit but this requires a Gas Fitter that is approved, as all sorts of tests, requires specialised equipment, if you have gas central heating, the service engineer could perform the same for your cooker. remember to ISOLATE MAINS POWER if this model uses it for ignition.
Hope this has been helpful
john
Jun 06, 2011 | Ovens
Kenmore Oven Model 278 4298891 everything appears to work but the oven turns on then a few seconds later goes off???
My daughters just experienced the same problem. I've tested what I could and only found some bad solier joints on the control board for the dial. I re soldiered the connections but still have the same problem. The temp sensor ohms at 1100 roughly and changes with temp changes. The elements pass a continuity check. The bake and broil relays seem to work fine but a few seconds after the relays close the oven just stops heating. Stumped! I guess I will look for a new control board.
Jan 17, 2011 | Kenmore 27841
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
I have a GE Spectra XL44 gas stove,but I'm having problems with the oven heating up.Sometimes after several attempts I get the oven operating, but most time stops at around 100 degrees. All of the top...
Yes, I think that you have a problem with the ignitor on your gas range.
As crazy as it may seem the ignitor can light your oven and then the power going through it drops off too much and it will shut your gas valve off. It sits there and goes crazy trying to relight all the time and never gets your oven hot. Sometimes it will and sometimes it won't... Drove me nuts the first time my own oven did that a few years back.
Here is a tip that will help explain it also. At the bottom of that tip there is also a tip on how to buy partson line.
Heatman101
Jan 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Gas does not always ignite
The igniter is not properly.Every time you go to light the stove you should hear a clicking sound.If you only hear it sometimes suspect the igniter..
Mar 31, 2009 | GE Kitchen Ranges
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool 30" Self-Cleaning Freestanding Gas Range - Black-on-Black Logo
100 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
