Question about Pioneer VSX-818V-K Receiver
Hdmi signal keeps blinking
I cannot get an HDMI picture.. somebody moved the receiver and did something... Now I cannot get a picture or sound.. The HDMI signal selet indicator keeps blinking.. I think this related to my problem
    Brigadier General:
  • 8,546 Answers
Check the physical conenction of the HDMI cable.
Posted on May 15, 2010
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
No picture when hooking component through receiver. Get sound but no picture. Tried to put ps3 in input 1, 2 and 3. Tried multiple cables as well
with Denon you have to go into the menu and "assign" the inputs.
You have to select if you are using HDMI, s-video composite etc.
If your unit has upconverting remember that it will upconvert a s-video signal to HDMI but not the other way around.
HDMI is a digital signal composite, s-video etc are analog therefore you could not use the HDMI output from your PS3 but then use the red, blue green composite outputs from your receiver to run to your tv.
Dec 29, 2009 | Denon Televison & Video
Getting picture lines across tv that keep scrolling down like old tv's used to do. HDMI connected to cable box. Cable box to tv works fine and dvd to receiver hdmi to tv works fine no picture problems. can...
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Dec 19, 2009 | Harman Multimedia AVR-254
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Yamaha htr6180 with Motorola HD Cable Box Causes Picture to Blink
Can't be done. Your version of HDMI firmware and hardware in your receiver have "handshake" and "HDCP" incompatability issues that are too costly to fix. Your receiver has version 1.1 HDMI and the current version is 1.3b and soon to be 1.4. HDMI is not to blame though; it's RIAA, the recording industry that keeps changing audio and video codecs to protect against "copyright infringement" It's a ROYAL LOAD of !@#$%^&*. I am in the industry and have been avoiding HDMI at all cost! Too many issues! even with current BLURAY players they are using RJ45's on the back to allow software updates to keep in line with all the new codecs. If you want more info on HDMI and it's many issues; google "HDMI problems" and you can read forever!. Sorry for the bad news, but it is the fact. Hope this at least helps in understanding that there is nothing wrong with your product! it's the recording industry!
Oct 23, 2009 | Yamaha HTR-6180 7.1 Channels Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
HDMI cable 30 ft to projector
The problem you are haveing may be the cable you are useing,if you can get a loan of a QEDor CHORD CO. cable try these,the chord co. cable comes with a line driver built into it and may solve your problem.Most cables for hdmi dont like 6 meters or over but i have had no problems with the chord co. or qed cables.
hope this helps.
CABLE GUY.
Jul 02, 2008 | Yamaha HTR-6090 Receiver
No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
May 05, 2008 | Onkyo TX-SR605 Receiver
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
Pioneer VSX-818V-K Receiver Logo
1,077 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
