Question about Samsung Refrigerators
The icemaker on my Samsung RFG295AARS will not empty the tray. I suspected a faulty heater, so tried a replacement icemaker, but still no luck. I have also already tried a replacement primary circuit board. Refirgerator is at 34 degrees and freezer is at minus 6. At my wits end now! Any help would be greatly appreciated.
SOURCE: refrigerator not cooling
Open the panel in the freezer, and take a hair dryer to the frozen coil.
Posted on May 13, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
tborn6
  • 700 Answers
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
SOURCE: Samsung Quattro-Cooling RM255LABP Freezer at +20F
orrixcreek i have the same problem. how do you go into the samsung diagnostic? i pressed different buttons at the same time and they're giving me gibberish i dont understand. which specific buttons to press and what exactly do the codes mean? i called samsung and they told me the fridge was probably in "demo mode" that is used on the sales floor and they had me pressed the two left buttons for 6 seconds and a bleep occurred and the LCD went dim. it really didnt fix the problem.
Posted on Jul 20, 2009
woodchuck789
  • 4059 Answers
SOURCE: Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
I have Samsung refrigerator RFG298 series the ice maker stopped working and sounds like a dog barking when it's running any ideas what it could be ?
Possibly the gear drive faulty in the ice maker, or it could be the dispensing chute has ice blocking it from closing properly. Completely empty the ice tray and make sure there is no ice anywhere in the tray, guides or ejection chute to the front door. On some, there is a little button under the icemaker for testing and forcing an ice maker operation. Press it and see if the ice tray rotates and reloads with water.
Nov 20, 2016 | Samsung RFG298HDWP French Door...
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Ice maker not dumping ice
It could be the harvest thermostat or the mold heater is bad on the icemaker. It is usually better to just replace the icemaker. Installing a harvest thermostat is a but tricky and the mold tray is 3/4 of the icemaker anyway..
Apr 08, 2014 | Refrigerators
Hello, I have an Samsung rs2533sw. the ice maker stopped working. it is at 8 degree. at this juncture, the manual reset switch does not work. if I let it unthaw then it works. once it gets cold it doesn't...
Hey heads up! The ice-cube maker has two parts... In fancy terms the business motor end, and the back-stop. Your back-stop is all busted. Mostly because it's been used successfully as a backstop for a few thousand times. The piece costs about $20, and you can get it at any Samsung parts distributor. The best way to check this is that your ice-cube tray will look like it's coming un-hinged in the back when it attempts to empty the ice.
When it works properly the ice-cube tray is actually contorted about 45 degrees from the front end to the back. The same way an adult male would crush ice.
Oct 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice cubes form a mass that do not dispense
Sep 11, 2009 | Kenmore Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Nov 11, 2007 | Refrigerators
Refrigerators Logo
164 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
