Question about HP LaserJet 1012 Printer
My HP laserjet 1012 smears the ink and wrinkles the paper on one side of the paper. What may be causing this problem?
    President:
  • 3,085 Answers
Probalbly the upper fuser roller has some of the film torn off. Look close with a flashlight through the back of the machine.
Posted on May 14, 2010
I'm facing the same problem. Running a piece if stiff paper through the path does not solve it.. What to do now?
Posted on May 17, 2010
    Brigadier General:
  • 4,090 Answers
Possibly a small piece of torn paper in the paper path. Run a piece if stiff cards through the path a few times to try and remove it.
Please rate my help++++Thanks for using FIXYA
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Problem with paper feed - all sheets come out wrinkled with smeared ink print
Sounds like your fuser is bad, ink is not adhering to the paper and building up on a roller that is causing the paper to wrinkle.
Oct 21, 2010 | HP LaserJet P3005n Printer
Hp 1010 Laserjet wrinkles paper
Typically, what causes wrinkled paper is the fuser assembly in the top rear of the printer. This is not a user replaceable part. I would first check to see if there is anything obstucting the paper path like a torn peice of paper or paperclip etc. You can take it to a printer repair shop to get the fuser replaced for around 100-150 dollars.
Aug 27, 2010 | HP LaserJet 1010 Printer
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
The paper comes out crumpled with smeared ink on one side
the problem is the fusing film of the printer. go to a store and try to change the fusing of your printer. sayedelyaskavesh@gmail.com
Jan 18, 2010 | HP LaserJet 1300 Printer
I have a problem with ink smearing on Southland fine linen paper on letters I've sent out The letters are folded in three and put in an envelope. The reciepients are recieving the letters with smeared...
Sometimes it's due to low fusing temperature. Certain papers need higher temps. Check the paper supplier or look in the printer setup menus and adjust the paper type to as close as possible to what you have.
Oct 23, 2009 | HP LaserJet 4250n Printer
The printer is printing little black dots on my documents
If the dots are all over the paper you may need to replace your toner cartridge. If the dots are smearing, you may need to check your fuser assembly (have it checked by a professional).
Oct 06, 2009 | HP LaserJet 1012 Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1012 Printer Logo
539 people viewed this question
Seeker5211
Seeker5211
