Question about Microwave Ovens
RV Microwave Not Working
When we plugged in our rv for the first time this spring, the microwave made a series of beeps and then the keypad stopped working. The display reads 0 and the light inside comes on when the door is open. Any suggestions for a fix?
  • 579 Answers
SOURCE: RV Microwave/Convection by Panosonic Model
I tried looking up the part number for this model and they don't identify clearly what the touch pad is. Would have to get one of the parts companys (andrewselectronics.com) to do research on it.
I've done surgery on a few touch panels and it usually works out. Have to break through the plastic tabs holding it together, then you can clean the contacts. Then do something like find little tiny screws to fasten it back together.
Hope Ya Fix It!
Posted on Jan 24, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp R-1850A Mocrowave Convection - No power
Chances are if the internal fuse and magnetron thermostat are good, then you have a circuit board that needs repair.
You can probably find exploded views at the Sears parts site. If you find a bad thermostat, the best place to order Sharp parts is Tritronics.
We regularly repair these control panels for customers nationwide (RV owners & dealers, too) with our guaranteed $39.95 service.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Instruction book required for High-Point microwave/convection
Here's a roundabout way to help you:
You can find a different High-Pointe RV microwave owner's manual here.
That manual should have contact info to help you get in touch with High-Pointe to get a new one, or it may be close enough to your model to work for you.
Posted on Nov 25, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
SOURCE: Our sylvania microwave model sr11092b received a
I had the EXACT same symptoms with my Sylvania SR1109sb after a power surge.
After some digging around I thought what the heck let me try holding down the Reset button and do a power off/on cycle and what do you know it worked !!!
Just pressing the Reset did nothing until the cycle off and on.
Ron W.
Posted on Jan 13, 2011
Why won't Microwave door stay shut?
We are having the same problem. Seems like latch spring is broken. We can not find any parts for this. Dometic is 3 yrs. old so no warranty. No service for it either. Keystone really took us on this
Jul 06, 2014 | Dometic DOTRC17B RV Microwave/Convection...
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
RV Panasonic Microwave cycling
The problem is in the keypad control board, eventually it will need to be replaced, also there may be a intermittent short in the keypad membrane this is where a professional will be needed to make that determination.
Jun 11, 2012 | Panasonic Microwave Ovens
Microwave wont work on generator power!
PLEASE CHECK THE POWER CONSUMPTION ON THE APPLIANCE i think it might be a lot more than ur gen set can supply
Jul 08, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Nov 24, 2008 | Microwave Ovens
I have an RV microwave that shows it has power to it because the display is on and the light to the chamber comes on and off when the door is open and closed. However, the keypad does not work. It is...
You can find your nearest Samsung-authorized service center here.
To find out about Samsung recalls, please call Samsung's Service Division at 800-932-3837.
Please let us know what you find out so others can benefit from the information.
Does the RV dealer know about this service?
Sep 28, 2008 | Microwave Ovens
Microwave beeps, error codes display and keypad stops working
It sound like you have a bad keypad or controls.
Is it possible that moisture from the sponge is getting into the controls?
You might contact the manufacturer to see if there might be a recall. I've seen keypad recalls in the past.
Anytime the keypad is suspected of coming on by itself, the oven should be unplugged when not in use.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Cuisinart CMW-100 Microwave Oven
Microwave oven will not work
Seems like I've answered this before, but the MR5493G is subject to a recall due to defective keypad (membrane switch) and can be seriously dangerous.
See: www.allworldauto.com/recalls/samsung_microwave_mr5493g_recalls_1420-10455-1.html
The MR1032BB is also under recall. See: www.motorbeat.com/model/samsung+microwave/mr1032bb/
If neither is covered under the recall, you should be able to order new keypads here: http://www.samsungparts.com/search/search.asp
If not, we'd be happy to help you. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2008 | Microwave Ovens
RV Microwave/Convection by Panosonic Model NN-8501V, touch controls go crazy when cold, indicating the AUTO DEF button is in continuous contact. CLEAR/STOP only works for a second and then AUTO DEF starts...
Hope Ya Fix It!
Jan 24, 2008 | Microwave Ovens
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung parts at http://www.samsungparts.com/search/search.asp
The keypad is also called the membrane switch.
Feel free to contact me for a more help if you need it.
Oct 24, 2007 | Samsung MC5694 Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
