Question about HP DeskJet 5550 InkJet Printer
I had a paper jam and I have removed the paper but I still have a problem. the little tear drop looking light underneath the top button is flashing and it wont print. what does it mean and how do i fix it.
    Novelist:
  • 116 Answers
The teardrop looking light is the Print Cartridge Status light.
If you have already removed the paper and still this light is blinking, then make sure you close the top cover. If it stops blinking, try to print again.
If not, then try the steps on this link.
It has the steps on how to make sure that the carriage can move freely.
I hope this helps!
Posted on May 14, 2010
Paper jam???
Follow these steps :
1.1
Remove all paper from the trays. This will prevent further jams during the clearing.
2.2
Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
3.3
Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
4.4
Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
5.5
Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
6.6
Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
7.7
Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
Oct 29, 2010 | Canon ImageClass D861 Printer
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam lite is on ( no paper jam )
give this a try
alternative :
May 28, 2009 | Brother HL-2040 Laser Printer
Canon MP600 paper jam
alternative :
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam flashing rx 425 did me best no paper in jam cant p0rint nothing
alternative :
Apr 22, 2009 | Epson RX620 All-In-One InkJet Photo...
Paper jam
reset by unplugging and then plugging back in, also make sure no paper is stuck in the rollers on top or the back....make sure all rollers are free of dust and if they have dust wipe off.....make sure you using the right type of paper and the printer itself isn't dirty....hope this helps
Apr 06, 2009 | Brother HL-2070N Printer
Paper jam message, but actually no paper jam
alternative :
Mar 25, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper jammed. Remove jammed paper and press the printer's RESUME button.
give this a try
alternative :
Dec 15, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
HP DeskJet 5550 InkJet Printer Logo
244 people viewed this question
Seeker5211
Seeker5211
