Question about Kenmore 22642 Top Load Washer
Washer will only dispense cold water. Both water sources are working to the washer. Any ideas The washer was recently moved to replace floor and put back. The problem did not show up until after moving washer
  • Kenmore Master
  • 5,568 Answers
There is a mixing valve normally located (and part of) the threaded connection for the hoses on the back of the machine.
These are junk when new and fail often.
Removing the back panel is pretty easy and the valve is normally not tough to reach and often held in place by 1 or 2 screws only with 1/4" or 3/8" heads.
If you have a Johnstone Supply in your area, the part will cost about half as much as from GE or Sears.
Posted on May 14, 2010
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sporatically slow cold water fill (Kenmore Series 80)
Could be you have trapped the hose at the rear of the m/c.
If this is not the case, then I suspect you will need a new cold inlet valve fitting..
Please leave feedback.
Ta.
Dec 09, 2008 | Washing Machines
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore side by side fridge not freezing after pwr went out for few hours
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Hotpoint HSS25GFP Side by Side...
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Softner dispenser
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Jul 02, 2006 | Frigidaire GSTR1670A Front Load Washer
Kenmore 22642 Top Load Washer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
