Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
I need the ip address to get into my router and cant seem to find the disk
    President:
  • 1,118 Answers
Try '192.168.1.1'.
Hope lit works for you.
Cheers! Carlos
Posted on May 14, 2010
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
Jan 30, 2013 | Smcd3gn-res Wireless Router Cable Modem...
I cant seem to get the right ip address
If you are looking for your own ip address try using www.ipchicken.com This website displays your current ip address
Feb 28, 2011 | NetGear WGR614 Wireless Router
I have lost the installation cd to my linksys router and I need software to change the wep password. I cant seem to remember what I have set it to before.
You can know your password without disk too. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 06, 2010 | Linksys Wireless-G WRT54G Router
I cant seem to figure out what is the IP address for my MSI RG60SE router.....
By default ip address is 192.168.1.1
or
192.168.0.1
But if your ip is different and if in your router DHCP is enabled then you have to check your computer ip address with which your router is connect.
Go to start menu then type in run "ipconfig /all"
then check gateway ip it is your router ip.
Also you can check your ip wtih phone reciver connect your phone receiver to router with phone line jack.
Then press * so you can listen configuration.
Let me kow if you need more assistanse.
Thanks.
Sep 24, 2009 | Computers & Internet
Wr850g cant connect to xbox live
I posted a solution under a different problem, but similar. Basically you will need to pick a static IP for your xbox. Then set that IP address in the router web config >> routing >> DMZ IP address setting. Restart both router and xbox and bingo. Your xbox is now directly connected to your cable modem without the router problems preventing connectivity.
Jun 19, 2009 | Arris WR850GP Router
Can only connect 1 computer to router
You might need to check if your laptop is able to get a valid IP address when connected wirelessly to the router. You can go to the Control Panel then click on network connections and look for wireless network connection. Right click the wireless network connection then click properties. Click the support tab and there you will see the IP address. You should not be getting 169.254.x.x. Where X represents numbers.
An IP address is very important. Make sure you're getting a correct IP address and it should be the IP address provided by your router. Without a valid IP address, you won't be able to get onlinwe. Your wireless connection can tell you that its connected eventhough its not getting a valid IP address.
Feb 07, 2009 | NetGear DG834 Router
Cant get into my router so i can do port forwarding
Try 192.168.1.1 for the IP address and admin for the user name.
Jan 16, 2009 | Computers & Internet
I cant seem to get my router working with my mac
Try checking your connection to the router first. If you're using DHCP connection or the automatically obtain ip address the router will give your computer the ip address try pinging your gateway. If there's a reply in your ping, your connection is normal. Is your problem about your internet connection using this router?
Dec 27, 2008 | NetGear DG834G Router
Open port 1024
IPchicken will give you your IP address
Dec 23, 2008 | MSI Wireless-G RG54G3 Router
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
104 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
