Question about Gateway GT5220 PC Desktop
My keyboard on my other computer is not working - I can't type my password in so I can start my computer -- the computer seems to be working ok! Its a gateway computer
My problem is some time my computer( gateway GT5220 ) working fine some time it dosent booting and bibing and green light is not going to on how can i solve my problem ?
Posted on May 31, 2010
    Sniper:
  • 65 Answers
Two things are a possiblity
1. Your keyboard has a short, and you have to get a new keyboard.
Or
2. The cable is unplugged (I'm sure you've checked) but hey it's a possiblity
Posted on May 14, 2010
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
New keyboard does not work
To connect or to disconnect the keyboard to a PS/2 port, follow these steps:
Shut down the computer.
Plug your device into the correct port. Make sure that the plug is pushed securely into the connector on the computer.
Restart the computer. Microsoft Windows detects the change, and then installs the drivers on the new port automatically.
If the issue continues to occur, try connecting the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
If the keyboard works on another computer, go to Step 2.
Step 2: Download and install the latest keyboard software
Step 3: Manually reinstall the drivers
To remove and then reinstall the drivers, follow these steps:
Disconnect the device from the computer.
Turn off the power for the device, if the device has a separate power supply.
Open Device Manager. To do this, use one of the following methods:
In Windows Vista or Windows 7, click Start, type device in the Start Search box, and then click Device Manager in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
Double-click Keyboard, right-click the keyboard that you use, and then click Uninstall.
If your device is not listed, this means that the device was removed automatically when you disconnected the device. Go to the next step.
First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
Jun 04, 2012 | Acer Computers & Internet
My keyboard and mouse are not working. 3 days ago when I last used my computer everything was working fine, however today when I tried to start it up I could not type in my password and the lights on my...
You have to log in to windows to fix this problem by borrowing a wired keyboard to enter your password. After log on go to Start-> all programs -> accessories -> system tools -> system restore and restore your computer to 3-4 days ago when it worked ok.
Jan 16, 2011 | HP P2360AA Keyboard/Mouse
Password will not work
may b a key board failure. Go to safemood aln check also.
When the machine boots up press F8
then go there and check. If its not a virus, it will work fine
If not you need to clean the keyboard
Thanks
Please rate the answer if it helps u
Jun 24, 2009 | ASUS Eee PC 701SD
Type on keyboard but nothing happens
in back of the computer swap the mouse plug with the keyboard. That usually works
Apr 14, 2009 | Computers & Internet
Gateway cordless KR-0401 Keyboard
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
Jul 19, 2008 | Gateway 2520915 Keyboard
Enter key on laptop
u can use an oncreen keyboard if ur running winxp. to do this, click on start,all programs,accessories,assecibility,onscreen keyboard or beter still use the tab key on yr laptop keyboard after typing yr password keep presing it untill the ok button or enter or next which ever one u want to activate when highlited, click the space bar key it should work as enter key.
guess this helps
thank u for using fixya
May 26, 2008 | Computers & Internet
I have forgotten my administrator password
  1. Reboot Windows in Safe Mode. To access Safe Mode, Click Start -> Shutdown (or Turn Off), and choose 'Restart'. Once the computer restarts, press F8 repeatedly on the keyboard until a Boot Menu appear (this *must* be done before the Windows boot screen appears). Finally, choose to boot Windows in Safe Mode and press Enter on the keyboard.
  2. Click Start, and then click Run.
  3. In the Open box, type the following command, and then click OK: control userpasswords2
  4. Click the user account that you forgot the password for, and then click Reset Password.
  5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Jan 03, 2008 | Microsoft Windows XP Professional With...
I can't get on my computer
Gateway GT5220 PC Desktop Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
