Question about HP Deskjet F4180 All-in-One InkJet Printer
Installation troubles I plugged in my usb before installation and now I am having trouble installing my printer. Help
  • 2 more comments
  • Janie Ison Mar 29, 2008
    I tried my solution and still get to same spot. How long does it take for the final step to download? Right now it says it the connecting device is counting down and the overall installation is at 94%.
  • Janie Ison Mar 30, 2008
    I thank you for the help. Even after following you tips I still got to the same place in the installation process. THANKS ANYWAY.
  • bronzepenny May 30, 2008
    I installed 4180 printer won't test or print.
  • Blackcat1 Jun 19, 2008
    Yes i have same problem
    Genius:
  • 3,587 Answers
Yeppers...
ok..turn off printer
unplug from computer
remove existing software from computer for printer
go here for fresh set of drivers
install in computer
follow instructions on when to plug in the printer.
see if that works forya
Posted on Mar 29, 2008
  • Patrick Michaels
    Patrick Michaels Mar 30, 2008
    now, why would you mark this as inappropriate? that suggests or implies that none of my information is useful. This is a standard approach to resolving this sort of issue..
    Perhaps you'll reconsider your decision.
SOURCE:
I have installed printer driver for Epson plq-22 but is not printing.what can I do
if you are using parallel port cable you must enable parallel port in bios. if you are using USB cable then for proper installation you must always install software FIRST then START software install, and only plug in printer when SOFTWARE tells you to as that is when it LOOKS for printer. make sure you only use the same usb port if you ever disconnect and re-connect it. you may need to go to PRINTERS and UNINSTALL any UNKNOWN device before re-installing. if you have a printer installed that you no longer use, UNINSTALL it as this can prevent a new printer working.If you insert printer first before software you may have trouble. If you also have 3rd party USB products such as Backup drive, then THAT SOFTWARE may interfere with install process and you may need to uninstall that software to make installing printer work.
Jul 25, 2016 | Epson Office Equipment & Supplies
How to install the printer without the cd
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 23, 2009 | Lexmark X1240 All-In-One InkJet Printer
I am trying to install a Lexmark, 3in1 p6210
Before plugging in the USB cable you need to install printer software.
If you have the original printer disk install software from disk.
Mar 01, 2009 | Lexmark Computers & Internet
I can't install my 4200 printer/fax. i get to the part where it says plug in usb cable, and it doesn't go beyond that. the cable is plugged in
Just for fun, try this: abort the installation process. Then plug in the printer in any USB port. Does the computer see the device? It should and then ask for a driver. If the system doesn't see the printer, then make sure the USB port is all right. Plug in some other USB device, such as a mouse, into the port. Does the computer see it? If not, then the trouble is in the PC. If it does, then your printer or the USB cable is bad. You can also take the printer to another computer and plug it in to make sure that it's all right.
Jan 31, 2009 | Lexmark X4270 All-In-One InkJet Printer
Hardware!!how come it will not install drivers,when i plug a usb printer in ,and the dvd player won't work!!!
Which OS are you using?
Model of the machine....
Does any error pop up ..or the machine freezes!
Nov 16, 2008 | Computers & Internet
First of all not very computer savy. having trouble with my printer. (hp deskjet f 380)i'm having trouble installing. a screen pops up that says wizard deleted by user?
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Oct 21, 2008 | HP Office Equipment & Supplies
Lexmark z735
Click right here.
A web page will open, select operative system, and click on download now loaction.
After downloading, find the file, double click on the file, if you get troubles , then follow instructions below to reset and reinstall:
  • Download driver from website and run the file.
Sep 10, 2008 | Lexmark Z640 InkJet Printer
Printer not working
Well now the installation did have trouble. I assume you used the CD. Do this Go to My computer/control panel/system/Hardware/device manager and make sure the the LAPT1 port is clear and then check that the USB devices is clear. Go back to the desktop Come off line Disable all A/V and Spy ware. Run the CD. If still in trouble come back
Jul 05, 2007 | Brother HL-2040 Laser Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
