Question about Protron PLTV3250 32 in. LCD Television
PLTV3250 32 in. HI Def LCD Television won't turn on - no lights on whatsoever outlet is ok just no power to tv
  • Protron Master
  • 8,457 Answers
Ur tv power supply board is dead.The power supply board,is the board where the a/c power cord plug into it.Take ur tv aparts replaced the power supply board,ur tv will get it power back and work again.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 14, 2010
Testimonial: "Thanks for the advise about the power supply board. I will try that first. The store I purchased the tv from wanted $105 just to look at the tv to give me an estimate! "
  • Chi Chu May 15, 2010
    They are ripping u off,why do they need $105 to diagnose the problems.U all ready told the the problems is."NO POWER TO THE TV".
  • 11,361 Answers
How do I fix the problem of the tv not turning on?
Checked Main's Cord is Ok or not.
Open LED Back Cover and checked Power Board.
Power Board will be defective
Dec 24, 2015 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sony KLV-27HR3 won't come on
Check to see if you are getting a back light by looking through the slots on the back cover. If you are getting a backlight then it is not your power board. If no back light check your connection in another outlet different room if possible or use a long extension. If still no back light then you are likely to need a new power board.
Good Luck Ed Pinero
Feb 03, 2013 | Sony KLV-27HR3 27 in. LCD Television
Blinking red light in front of tv (lamp) and noise coming from tv as well.
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2200. You can download the manual of the TV by clicking here. Refer to page # 76 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KDF-E55A20 55 in. LCD Television
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
Standby light blinks 4 times
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Kdl-52xbr4 5 blinking standby lights
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
I have a sony wegs lcd tv with a seperate monitor and media centre. when I turn the media centre on the monitor lights up green on the stand by light and then afetr a couple of seconds the monitor switches...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi Def from dvd player
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Jul 30, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Protron PLTV3250 32 in. LCD Television Logo
412 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
