Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
What is the valve setting for a briggs and stratton moel 407777 engine
SOURCE: Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
Posted on May 15, 2009
  • 583 Answers
SOURCE: briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
kel1guy2002
  • 3740 Answers
SOURCE: how do set valve lash
Turn the motor until the piston is at TDC. Look through the spark plug hole. piston to top of the cylinder. Then set them like you would any OHC rocker arm. BE very careful with the exhaust valve adjustment. There is like a mini disc on top of the valve stem spring keeper. If you get it too loose on a vertical engine it can drop out and it will take you forever to find the little bugger!
Below is only a recommendation....
I don't know how many hours that are on this engine your working on but... I would recommend you hand lap the valves with grinding compound if you know it has high engine hours. It will make it easier to start and have more power. The exhaust valves on these engines get very noteable black gunk buildup in the seat to the point you can not see the "valve to seat" mating ring on the valve head. The heads are not hard to remove... (One at a time) just time consuming. It can be a chore getting the valve push rods aligned with the engine horizontal. Most of the time and I know good Mechs don't like to hear this.. you can reuse the cyl head gasket on this model due to the design. Once in a while they break not very often.
The valve springs have keyhole locks on the keeper.
Thanks for using FixYa,
Kelly
Posted on May 01, 2010
  • 3 Answers
SOURCE: Briggs and Stratton 6.5 hp
The crankshaft should have a marked "tooth" either with a "dot" or a "-"mark, the camshaft will also have a corresponding dot or dash. By rotating the crankshaft, align the marks on the crankshaft & the camshaft so that they are directly opposite each other. Drop the camshaft into place and the engine is now "timed"--if the marks are not exactly opposite one another, lift the camshaft (just enough to disengage the gear teeth) and try again, being "one tooth" out can make a huge difference--so take your time and make sure the "marks" are directly opposite each other.
Posted on Aug 10, 2010
I need the engine torque specs for a Briggs and Stratton Model: 407777-0170-g5
http://outdoorpowerinfo.com has the specs for almost everything
Jun 09, 2017 | Briggs Garden
Repair manual for B&S 407777/0128E1 engine
For a repair manual, contact Briggs & Stratton directly.
May 19, 2017 | Briggs & Stratton Garden
Valve settings
Intake is .004
exhaust is .006
Aug 05, 2014 | Briggs & Stratton Garden
Briggs 407777, type 0121-E4
The engine is not developing power and the presence of a load causes it to slow down and quit all together. Is there some sort of timing advance on that motor? In a car if the timing is not right that is exactly what happens when you put the car into gear and try to use it.
I would not mess with the valves till I check out the timing.
Nov 24, 2013 | Briggs & Stratton Garden
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
Need manual for briggs 407777 0229e1 trying to replace crankcase gasket something fell out im tryin to decide how to put it back together do you remove the round plate at the bottom to insert this small...
An exploded parts diagram is available here:
http://www.briggsandstratton.com/engines/support/?NTT=4077770229E1
There are service manuals available here:
http://www.jackssmallengines.com/Products/BRIGGS-STRATTON/Manuals
Oct 04, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Intek ohv 19hp V twin modell 407777. Lawn tractor, while mowing, rpms went higher then went full thottle. Throttle level and cable apear to be working fine but the rpms are unefected by it. Visual...
Had the same problem with the same engine. Governor control in the base of the engine fell apart. Requires pulling the engine which is pretty easy, then removing the bolts along the bottom of the crankcase. YOu'll see the governor and or pieces in the bottom. Use a magnet to get all metal pieces from the oil, then replace the governor. Get the model and type off the valve cover from the engine when replacing governor. 3 hour job and you're done..////While it's out check the valve lash by removing rocker covers. Set them at .006 or a tight 007. That way you'll know it didn't through a pushrod when it was over reving..good luck
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18.5 hp briggs 2006 model 407777-0174E1 flooding
If the key is left on it will open the solenoid but it still shouldnt leak unless it has a peice of dirt or foreign debree in the carb clean the bowl out also in the future I have always put a fuel inline shutoff valve on the fuel line for about three bucks never have a problem with excess fuel just remember to turn it on and turn it off
Nov 06, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
193 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
