Question about Honda Garden
What is the gas oil mix? Hoffco Li'L HOE - Honda Garden
24 : 1= 1 gal gas to 5 oz oil
Posted on May 15, 2010
How do I set the idle for Hoffco Ll'l Hoe engine
The start setting on most 2-cycle engines are as follows for the jets:
The Hi speed is 1-1/2 turns out from closed, and 1 turn on idle or low. Actually they are the same on 4-cycle too. The idle adjustment screw is a separate screw with a spring on it. This will push the throttle arm to give more or less idle. For more info, go to Partsree.com.
Jan 20, 2015 | Tecumseh Garden
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Jun 24, 2012 | Boating
I have a Hoffco Lil'l hoe and it will start for a few seconds and then stop. Last year I took it to a local small engine repair shop and they just half fixed it because a couple uses it became hard to...
Make sure your air filter is clean and you are using brand new petrol. If you left old petrol in it it may have clogged up the carb. It sound like no fuel is getting to the spark plug. If you have a rubber priming bulb, press it slowly and regularly to try and keep the engine going once you have it started on starting fluid. Good luck.
Jun 25, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
Cant find transmission parts for my hoffco lil hoe. It has a Tecumseh engine
Most Honda Parts Fit http://www.lawnmowerstuff.com/163-Honda_FG100_Parts.html
Jun 01, 2010 | Garden
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 | Garden
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 | Garden
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 | Garden
Garden Logo
170 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
