Hi I have a Technics system sc- eh 600, having trouble turning it on we press the power button comes up F61 then says goodbye. cant find anything about it.
3 Suggested Answers
tech48
  • 624 Answers
SOURCE: Error code F61 on Technics SC-DV150
The F61 error is an amplifier failure.This error can be caused by a blown channel or even a failure in the power supply which causes the unit to detect an amplifier failure because the power supply is not supplying the proper voltage to the amplifier. On more rare occasions this can be caused by broken solder connections in the amplifier and/or power supply. Without having the receiver in front of me to troubleshoot it is impossible to tell you exactly what the cause is.
It can be fixed, but it will require some decent electronic skills. If you do not have a multimeter, soldering equipment, and an understanding of electronic components it would be best to let a service center look at it for you. If you do have these tools and would like to try and fix it yourself, let me know and I may be able to guide you thru the troubleshooting process.
Dave
Posted on Nov 26, 2008
  • 336 Answers
SOURCE: stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Posted on Oct 16, 2009
My technics SC-HD 51 does not respond to power on when the power button is pressed ,what fault can that be?
Take your pick, the power switch itself, Mains transformer, blown fuse, anything in the power supply that's fried or has died.
Jan 25, 2016 | Technics Audio Players & Recorders
Hi, my Panasonic saak-600 had the f61 problem , I change the ic stk 470-090 and the f61 dissapeared but when i turn off the system it automatically turn on after few seconde without turning on by...
seems the system is fine and what you see is display demo of the system.
while the system is on standby or even if it is on keep pressing the display button
until "no display" is displayed on the screen.
Nov 17, 2010 | Panasonic SC-AK600 CD Shelf System
Stereo does'nt stay on you turn it on and it just clicks n goes off technics dv290 system
problem with amplifier contact dealer,i have the samne problem with mine,its shows F61 on the diplay and when i check my user manual it states there is a problem with the amplifier
Dec 09, 2009 | Technics SC-DV290 System
Stereo system technics sc-dv150 showing fault f61 how do i
Oct 15, 2009 | Audio Players & Recorders
Technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Demo will not turn off
Hello!, i'm the same problem with a eh-770 before a cut of electric fluid. I resolved the problem setting the clock of the unit.
Jun 07, 2008 | Technics Audio Players & Recorders
F61 problem
DIsconnect sound Amplifier ic (RSN).After removal of the ic if the unit works o.k offcourse without sound than replace ic.If still f61 than sound ic is o.k and check voltege regulators in power supply.You can check dc detect line if it gets activated.
F61 is mainly two resons 1st sound ic or power supply problem in power bord which send signal to system control to shut down the power in order not to damege more.
Dec 13, 2007 | Technics SC-EH780 CD Shelf System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
100 people viewed this question
 Grubhead
Grubhead
