Question about GE 24 in. PDW9800L Built-in Dishwasher
Glasses that have "sand like solutions" in them after a wash
I run the d/w with added heat to dissolve the soap- but the top rack glasses always have junk in them. Can I pull the heating element & get it tested? I am pretty sure it is not heating- as the water temp is about 94 degrees- same as the tap water- maybe a bit higher when it runs for a bit.
All 3 spray arms are cleared and water comes out of them.
If so- how do you pull the water heater out?
  • GE Master
  • 43,501 Answers
The soap doesn't dissolve and sometimes the plates are still dirty.
Start dishwasher. Stop after a minute or so. Check the water level in the tub. On a older model I would expect about 2 inches of water in the tub. About 1/2 inch or so below heater.
If water OK than I assume you can hear the pump running.
If pump running and enough water than I would assume a blocked wash arm.
  • First rotate by hand and make sure that it doesn't bind or interfere with rack.
  • Check carefully the holes at the ends of the arm looking for debris that collects. Seeds and such love to collect at the tips preventing the jet of water that provides the rotation force from escaping. Use small tweezers to grab debris and pull through hole
  • Blocked water return screen. Look for clear plastic etc that covers the return of the water to the pump sump.
  • Place small cups right side up in upper and lower rack. Cycle machine for a minute or so. Confirm cups are filling with water!!
If all checks OK than try running water at sink for several minutes to confirm water is very hot. Start cycle knowing inlet water to dishwasher is hot. Evaluate results.
Dec 09, 2015 | Kenmore Dishwashers
Detergent tablet will not dissolve?
Check water temp in might be to cool that is the first step......
Oct 06, 2014 | CDA WC430 Dishwasher
Top rack not washing. All soap not cleaned out of dispenser
This may sound ridiculous, and I'm no "expert", but are you starting out with really hot water (i.e. running the faucet at the kitchen sink until hot water comes out)? My wife refuses to do this and she encounters the same problems: dirty dishes and leftover soap. *I* make sure that hot water is readily available to the dishwasher (even though it's *supposed* to heat it for you) and never have either issue.
Feb 07, 2012 | Dishwashers
Dark clothes have lint left on them. what could help this problem?
Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
If it is lint, always keep the lint collector inside the agitator clean.
If it is soap, and this might work for lint:
1. Turn clothes, particularly black clothes, inside out.
2. Use a concentrated soap with little or no filler.
3. Use less soap than normal.
4. Fully dissolve soap before adding clothes.
5. Run rinse cycle again after completing full wash cycle.
Jun 22, 2011 | Admiral AW22 Top Load Washer
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
There has been a trail of dry soap on inside of door after wash is complete, also dried soap on some dishes in bottom rack as well as not being clean and on top rack spots on glasses and sometimes some...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2010 | Hotpoint 24 in. HDA900X Built-in...
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Kenmore Dishwasher leaving SAND behind
1. Remove the top rack and lower rack.
2. Remove the lower spray arm by holding the top of the center hub and rotating spray arm counter clockwise.
3. Remove water tube feed from the back wall of the dishwasher by unclipping at top and back. Pull towards you and lift tab at the bottom on the big tube to remove the plastic clip from main water feed.
4. Remove the main water tube by turning quarter turn clockwise, then lift off. Keep the center hub from falling out so you don't lose the plastic washer.
5. Using a star tip screw driver; remove the four screws and lift off the filter cap assembly. The assembly consists of the screen filter and the food trap grate (The outer edges look gear like).
6. Look down inside this area and clean out anything foreign. usually there will be seeds, paper, and other gook. I used tweezers, toothpicks, and needlenose pliers. I remove from my dishwaser quite a bit of paper, two wooden match sticks, lots of undissolved soap etc.
7. When you have removed as much as you can, put everything back together in the order you removed it.
8. When you run the next cycle, you should immediatly hear more noise to indicate that you have cleared the pathway that allows water to flow at its intended pressure.
Apr 09, 2006 | Kenmore 24 in. 16309 Built-in Dishwasher
GE 24 in. PDW9800L Built-in Dishwasher Logo
49 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
