Question about Linksys WRT300N Wireless Router
I can't get my laptop to connect to the linksys wrt300n router. My laptop "sees" the router as it shows a 92% signal, but when I click on "connect" it doesn't let me. Help! I have an Acer Extensa 4420 laptop.
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
chocoberry
  • 94 Answers
SOURCE: My WRT300N Linksys router shows all lights, I've
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Posted on Dec 30, 2009
router-user
  • 550 Answers
SOURCE: My Linksys wrt300n wireless N router is slow
You have WRT300N router. If it is very old model then upgrade the firmware of the router. and try changing the wireless channel on the router.
Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Posted on Apr 27, 2010
router-user
  • 550 Answers
SOURCE: After i touched the reserved button, the router stopped working.
Did you press the Reset button on the router ?
If you press the reset button then the router will come back to the factory default settings. You will need to reconfigure the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 01, 2010
SOURCE: how to configure linksys wrt300n router
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on Jun 15, 2010
Unable to connect PS3 to linksys wrt300n, key exchange timed out, signal 100% and key is correct?
For instructions on setting up the PS3, Xbox, or Wii, for a wireless/Internet connection. please click on this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 08, 2012 | Linksys Wireless-G WRT54G Router
How to set up Linksys WRT300N Wireless Router
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Aug 30, 2011 | Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Dec 30, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300n will only allow local access wirelessly
go into the router interface and see if it is set for DHCP and reboot systems it should be fine
Jul 17, 2009 | Linksys WRT300N Wireless Router
My xbox can not connect to the router wrt300n
You will need a signal extender.Normaly the signal shoud be enough to make a good connection but that depends on the enviroment.
May 04, 2009 | Linksys WRT300N Wireless Router
WRT300N wont connect wireless
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Linksys WRT300N Wireless Router
Linksys Wireless WRT300N
Try going to the configuration page and check if it is sending a wireless signal.
Dec 24, 2008 | Linksys WRT300N Wireless Router
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Router problem
Make sure you have the wireless icon on the taskbar lower right side. If it does not show connected, click the icon and search for wireless devices, you should see the router. connect to the router. Also make sure you have a solid DSL/CABLE status light on the service modem. BPCS
Dec 28, 2007 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
83 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
