Question about Kenmore 43142 Front Load Washer
What does sud mean? - Kenmore 43142 Front Load Washer
  • 5,911 Answers
"SUD" is a Suds Detect error code. The following link explains the error and some potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error comes from using too much, or the wrong type, of detergent. You are required to use High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any manufacturer warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it from time to time to troubleshoot your washer.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Posted on May 14, 2010
What does Sud mean?
Too much suds from possibly too much detergent or incorrect detergent.
Whats Causing your Washing Machine to Sud Mama Laundry Talk
Mar 20, 2016 | Washing Machines
Tip
Sud mean
over dose of detergent detectd during the wsh cycle ////// the motor control unit senses a suds lock condition by analyzing the current draw on the drive motor . if "sud" is displayed a potential suds lock is detected . this may signify a badpump an extra heavy load excessive detergent or excessive suds.................
on Aug 05, 2010 | Washing Machines
What does "sud" mean on the time remaining display?
You used to much soap producing too many suds. Too many suds interferes with operation of machine. Read your owners manual
Jan 06, 2013 | Kenmore HE4t 3.8 Cu. Ft. Plus Front Load
I'm getting an 5ud and don't know what that means?
Hello, Thank You for using FixYa. I will be helping you today.SUD means suds as in soap suds. Are you using too much soap? Are you using high efficiency detergent? If your using the correct detergent and not using too much,Only fill to bottom line on cap and still getting sud error then you may have a failed pressure switch.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Kenmore Front Load Washer
What does '5ud' or Sud displayed on the light console mean?
It is meant to be SUD rather than 5UD and it stands for 'suds'- too much sudding. Machines normally go into a mode to flush the suds out at that point. As a suggestion it could be you are using too many tablets/too much soap powder.
John C
Feb 16, 2011 | Whirlpool Washing Machines
Do you know what problem 5d or Sd means
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer showed a code 5d what does this mean
5D actually means suds, make sure you aren't using normal detergant as these units require 'HE or High Efficiency' detergant that doesn't suds much. Try runing a load with not clothes and just put in a cup of white vinegar to remove all the suds in the machine and see if goes through spin with no suds in. If not and you still get an error you will need to replace the pressure switch because it thinks there is water or suds in the machine it's not removing.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2011 | Maytag EPICz 3.7 cu. ft. Washer
What does sud mean on the washer?
it means suds, u have either used an unapproved detergent that suds up to much or u used to much soap
Sep 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 43142 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
