Question about Keurig Platinum B70 Coffee Maker
K--cup holder (pod holder is broken need another
    Sniper:
  • 67 Answers
If you are talking about the black funnel part? then this site sells them http://stores.ilikenew.com
Posted on Nov 17, 2010
    Champion:
  • 213 Answers
3 Suggested Answers
cmccune04
  • 213 Answers
SOURCE: Keurig B3000 K-Cup holder and pivot broken - need replacements
http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-K-cup-Holder-Assembly-Part-J-P1208231.aspx
This will fit your model
Hope it helps you
Posted on May 26, 2010
cmccune04
  • 213 Answers
SOURCE: metal pin does not poke thru the pod
Do you need the top or bottom one? either way we have them here; http://www.igotsweetdeals.com
Posted on Jun 14, 2010
Why wont lid on my phillips senseo hd7863 close when the pod is in the holder ?
Maybe you inserted the pod with the wrong side up or you used a 2-cup pod in a single cup holder. If the clamping spring isn't working (the lid feels loose when you try to close it), that spring (that is nothing more than a straight piece of metal wire) needs to be replaced.
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
I need to find a replacement K-cup recptacle holder.
are you talking about the black funnel, where you put the k-cup pod? if so i know this great site that sells them : http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok i hope this helps
Jan 16, 2011 | Keurig B60 Coffee Maker
The water will not go through the pod to make the coffee. If you remove the pod then the water flows. If you want tea the water goes through with no problem. We tried the vinegar but that didn't work...
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
May 17, 2010 | Keurig Elite B40 Coffee Maker
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
Metal pin does not poke thru the pod
Oct 16, 2009 | Keurig B50 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
571 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
