Question about Dell PowerEdge 2950 (becwfk1_6) Server
Unable to boot dell power edge 2950 from cd/dvd drive.....
  • Kibidongo May 14, 2010
    Does anybody know the secret keystroke sequence that Dell Support uses to force a boot from cd/dvd drive? (Dell PowerEdge 2950)
  • Dell Master
  • 13,433 Answers
Have you tried changing the boot order from bios, how about are you absolutely sure the cd you have is bootable? does it boot on another machine?
Posted on May 14, 2010
  • 1,472 Answers
Jim6387
When you are booting the system are you pressing F12 to get to the boot menu or are you trying to boot from the ROM via the BIOS settings.
Also what disk are you trying to boot from.
Issken
http://www.fixya.com/users/issken
Posted on May 13, 2010
  • 2 more comments
  • Kibidongo May 13, 2010
    I am trying to boot from BIOS.
    I have reinitialized the virtual disk and that looks "OK"
    I have a Windows Server 2003 R2 64bit disk in the drive, but cannot get the bios to boot from the drive.
  • Will Hartford
    Will Hartford May 14, 2010
    jim6387
    I guess I am a little confussed do you have the Windows Server CD in the actual ROM drive or are you trying to boot from a virtual drive.
    Issken
  • Kibidongo May 15, 2010
    Hello ISSKEN,
    I have the actual DVD in the drive. The 2950 has the PERC5i RAID controller and 4 physical disks in RAID 0, so it appears as one logical drive to the OS.
    Four days ago, I was successful at installing Windows 7 64bit "OS", and during that install; Win7 downloaded a new driver for the RAID card....and I think my trouble lies there. I am going to try and make the Dell firmware and Driver floppies and go from there....
    Any advice you have will definitely keep me sane over the weekend!!
    Best Regards,
    Jim
  • Will Hartford
    Will Hartford May 15, 2010
    jim6387
    Yea that could be the issue especially if you have any older Firmware installed with the PERC 5i.
    Note in regards to the firmware and drive update check if you change the operating system over to Windows Server 2008 x64 you can download the Update Package for Microsoft® Windows® to install the firmware and drivers from Windows instead of having to use a floopy disk.
    Let me know if you have any more questions
    Issken
Hello, why my cd rom cannot read my dvd?
Try another DVD. Is the data cable connected? Can you see the drive in Explorer?
May 13, 2014 | Dell PowerEdge 2950 (becwfk1_6) Server
PC turns on but will not boot up; unable to run directly from cd rom
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
I have a Dell Power Edge 2950 running on Ubuntu. Is there any program that i can run to check my hardware because i had a Error message E1810 HDD disk failure. i remove the disk and put it back on but i...
You may have a damaged hard drive and it needs to be replaced. If the system is still under warranty, Dell will replace the drive free, you just need to go online, supply your systems tag number and follow the instructions from there. If you have just the one drive, you will need to restore the information froma a backup. If you have a RAID set up, once the hard drive is reinstalled, the RAID will sync the drive to the others.
Good Luck
C2Solutions
Oct 14, 2011 | Dell PowerEdge 2950 (becwfk1_6) Server
My dvd rom will not read my iso image cd for a boot. but it will read factory made cd.. help i need to update my raid controler i have at dell 2950 server running MS2003
If you have a spare USB flash drive lying around, you could try using http://unetbootin.sourceforge.net/ with the ISO image. Then, hit F11 while the 2950 is booting and you should be able to select the flash drive.
If that doesn't work, see if you can find updated firmware for your DVD-ROM on http://support.dell.com or if it's an aftermarket install go to the OEM's support site.
Failing that, maybe try different media. If you're burning to a CD-R, try a different brand (and avoid CD-RW discs.) If you're using a DVD-R, try a DVD+R.
Oct 14, 2010 | Dell PowerEdge 2950 (becwfk1_6) Server
Dvd laptop have problem, dont read cd and dvd model: dell vostro 1510
check whether you are able to boot fom operating system cd/dvd,
if you are able to boot fom OS cd/dvd, there is no hardware issue,
if unable to boot = Replace optical drive
then software troubleshooting
Install firmware upgrade for optical drive fom suppot.dell.com
reinstall Operating system.
Jan 31, 2010 | Dell Vostro 1510 Laptop
Dvd r/rw on Dell E1705 laptop computer quit playing cds and dvds. Makes grinding start up noise but does not play
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
pOst back what were the diagnosis
Thanks
proton
Apr 11, 2009 | Dell Inspiron E1705 Notebook
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell PowerEdge 2950 (becwfk1_6) Server Logo
1,815 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
