Question about Sony Playstation 3 (PS3) Console
PS3's only read FAT32 USB's however movies over 4GB cannot be transferred to a FAT32 USB. I have reformatted to NTFS but the PS3 does not read this
    Master:
  • 441 Answers
If you have files that are over 4GB they are not supported on the PS3, this may include 1080p HD quality video that you want to play on your Playstation 3 and cannot because the current FAT file structure does not support files more than 4GB. The answer would be a PS3 firmware update to support the NTFS file system, then you could play 4GB plus video files on your PS3.
Posted on May 14, 2010
Testimonial: "Many thanks will look into firmware options"
I have a panasonic blu ray home cinema system, it says my usb isnt compatible cannot read it, trying to play music via a portable hard drive
It may be in the wrong format, there are 2 main format for usb hard drives, FAT32 and NTFS. You may have to reformat to a different format to what you currently have. To do this, you will need to plug it into a computer, go to Computer and right click on your drive and select format. Select either FAT32 or NTFS, make sure there is a tick in Quick Format and then click start. Please note, this will erase all data off your USB stick so make sure to copy all your data to your computer before you do this. If it doesn't work, then try the other format i.e if FAT32 does not work try NTFS. And just as a side note, the main difference between the 2 formats is FAT32 will not allow you to copy files over 4GB while NTFS will.
Dec 05, 2014 | Panasonic Audio Players & Recorders
N723 drives
try opening in a linux machine and you should have all the hard drive files still on there ready to be used and take them and then reformat you hard drive once you have moved your files to a safe place. and then format back to fat32(works on both mac and windows although limit is only 4gb single file sizes are allowed) or ntfs (only works for windows machines)and copy and paste files back onto the drive. It may already be in NTFS format if so copy all files on a windows machine and save safely then reformat the harad drive into Fat32 :D movies shouldn't be bigger than 4gb each so any files that are smaller will be fine
Oct 30, 2013 | Computers & Internet
Can't download a 10 gb movie into 32gb lexar s73 jumpdrive. it says it's full
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Jan 28, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
When i plug my usb external hard drive in, it does not even show that there is a usb drive
If your Ext. HDD has been formatted in NTFS the TV might not detect it. Transfer the files on to a PC then reformat the HDD in FAT32. Then reload the movies , most probably the TV will read the files.
Aug 06, 2011 | Toshiba 32AV600E 32 in. TV
My 1.5 tb mybook has been formatted to fat32, and i cant watch movies on my ps3 no more loads up files really slow even freezes. Also disappears on my laptop sometimes then reappears. But transfers and...
FAT32 was the file type used for the early Windows operating systems. With the release of Windows NT and XP it switched to NTFS file system. FAT32 is still used however to transfer data between Mac and PC. The downside of FAT32 is the files read slower and file size cannot exceed 4GB. If you do not use a Mac I would suggest using the Disk Management utility in Control Panel under Computer Management to convert it to NTFS.
Mar 16, 2011 | Western Digital My Book Essential Edition...
Trying to put 6.56GB movie on my 8GB sandisk cruzer contour, says the file is too large for the destination file
The file system is likely the culprit for this. If you've formatted the USB stick with FAT32, the largest SINGLE file will be about 4GB. You can place as many smaller files as you want to fill the stick completely (in excess of 4GB), but once you approach 4GB for a single file - it will crash.
Format with NTFS instead. No 4GB limit is placed on files in this file system. A nice chart listing the differences between file systems can be found here. The forth row "Max File Size" shows the data you're asking about. NTFS supports 16TB (terrabytes are 1000 times larger than gigabytes) while FAT32 is limited to a "paltry" 4GB. Both FAT32 and NTFS are supported by Windows XP and newer OSes.
I hope this helps - please rate my reply - thanks!
Dec 28, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I have a sandisk 8gb usb stick, I am tryind to copy files from windows xp to it but cant, i keep getting file not specified error. I can copy over small files on to it but nothing big. I know the stick is...
You need to re-format your Flash Drive. The default is FAT32 which only allows files of up to 4GB to be transfered. If you reformat to NTFS, ANY size file can be copied to your FLASH DRIVE.
WARNING ! ! By reformatting, you will loose ALL your data on your Flash Drive. Good Luck
Dec 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When i plug an external harddrive in to the ps3 it isn't picked up.Why?
If you highlight "USB Devices" and then press triangle, you should then be able to select "Show All". Your files should then be shown on your external hard drive. If this does not work then it may be because the drive is formatted to NTFS instead of FAT32. The PS3 has trouble reading NTFS devices. If possible reformat the drive to FAT32 using a program called "Fat32format" which is available from here .
Hope this helps and thank you for using FixYa
Sep 21, 2010 | Sony Playstation 3 (PS3) Console
I can't transer file sizes more than 4 GB... What I've done to get around this is save my movies in multiple parts to make each file size smaller. Is there something I need to be able to transfer my files...
This will be a limitation of file size imposed by your operating system and drive format method. For drives formatted under FAT16 (2Gb) or FAT32 (4Gb - 2 bytes). FAT64 allows up to 16Zb while NTFS and NTFS5 both allow any size up to the actual volume capacity so with a 500Gb drive the max would be 500Gb for 1 file. I would therefore suggest that you retrieve all your stored data on the drive and reformat it with NTFS. Then you can have 1 continuous file instead of lots of 4Gb files.
Nov 02, 2009 | Western Digital 500GB My Book World...
I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
Oct 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sony Playstation 3 (PS3) Console Logo
976 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
