Question about Parmak Solar Fence Charger
Need battery Unit is 6-7 years old. Cleaned entire fence line and set up fence the same as in the past. Unit shows in the red. It is located app miles from my home and I havent checked it since it has been set up. Maybe it was not out long enough to fully charge. I still would like to Know where to get a battery for it. Thanks very good dependable Unit. Ron
  • 454 Answers
We have one of these, it's great.
See these links:
http://www.parmakusa.com/Battery_Maint.htm
http://www.parmakusa.com/service.htm
I would try removing the battery and charging it with a proper low-amperage charger (1 amp). Your battery will either be 6 volt or 12 volt, just be sure the charger matches.
Also check the ground rod and all wiring connections.
Posted on May 13, 2010
My chain link fence is rusted in a few different areas. Should I replace the entire fence, or is there a way to fix it?
Hi Jessica:
Surface rust should have no effect on the structural integrity of the fence, and a totally acceptable cosmetic fix should be able to be obtained using galvanize paint.
Notice I said COSMETIC fix. If the fence is no longer structurally sound, it may be time for some major repairs or replacement.
Jul 15, 2015 | Home Fencing
Troubleshooting back-up malfunction after replacing battery. Checked main power supply breaker and battery power supply fuses for continuity. What should I try next?
Depending on the type of unit, you do not state any model. It may require 6-8 hours of being plugged in and turned off before the battery has enough charge that the ups will turn on.
Feb 08, 2015 | Power Computers & Internet
Hi, I have a 25 mile range Parmak solar pak 6 fence charger. When I test the lines it reads .02 and I noticed that the energizer unit itself is energized. I tested the unit and it reads between 3.8 to 4.6....
Any point you measure has to be compared to a reference. This can not be accomplished by just touching one spot....it must be compared to something. Do I make sense the way I explain this?
Hope this helps! Good luck
Dec 30, 2013 | Electrical Supplies
Parmak 6 is showing the volt red line is pass the green charge line and it doesn't have a good charge, it's very weak and everything is clear - nothing touching the wire.
I would first start with the battewry, 2 year run on battery is pretty good. You can go online and find replacement batteries or go to place of purchase and check with them.
Oct 25, 2017 | Parmak Solar Fence Charger
My monarch ESC16 had both red lights on today. salt
If you are sure it was cleaned correctly, it most likely will be a failed cell. Warranty thru this company has become very difficult in the past few years as the company had a falling out with its US counterpart. Good Luck.
Feb 14, 2010 | Hayward In Line Chlorinator 9 Lb. Capacity...
I have just purchased a Delta Rockwell Industrial Table Saw. It is a 1.5 HP, 3 BELT, 3 PHASE UNIT. How should I clean and lubricate the parts. I also bought 22OV 5 HP motor to put in it because I only have...
The table can be cleaned and waxed with a good quality paste wax like Trewax clear. If it has rust, you can use automative polish/cleaner and a rag or fine scotch pads to get the rust out, then wax the surface to protect it. Period waxing will maintain a low friction surface through use. Old timers used to recommend rubbing the bare steel table with talc to seal the pores, but I find was is more readily available and gives a better surface for use...Wax is also good on the moving parts of the fence.
The worm gears and trunnions can be cleaned with compressed air and regular 30w motor oil in a pump can. Maybe a soft wire brush or toothbrush if needed to remove built up resin and pitch. If there's a really heavy build up on the gears, get some OxiSolve bit and blade cleaner from Woodworker's supply and it will safely dissolve the gunk to a consistency you can scrub off with a toothbrush. I maintain these moving mechanical parts with oil, which an old pro recommended years ago, and have found it doesn't contribute to sawdust build up as you think it might, not nearly so much as an assembly lube or white grease, and makes raising and lower the blade a joy. If you're concerned about dryness, you can try triflow or some kind of bicycle chain lube, but I've decided the expense isn't worth the results, and oil is readily available when I need it...
If replacement parts are available for your model, try here. Otherwise, and for older machines, you might find a manual or parts info at this site.
After market fences are available for your saw, and depend on user preference. I've been very happy with my Biesemeyer fence, after using it (and many others) for 22 years. It is also heavy duty.
Jul 18, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Parmak Solar Fence Charger  Logo
248 people viewed this question
Top Parmak Electrical Supplies Experts
Craig Butler
Craig Butler
Steve Pack
Steve Pack
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
