Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80s Series Leaks Water into the Bin
My washer, a Kenmore 80 Series top loading, leaks water into the bin. It just comes out of the place I guess where water normally fills from. Any advice would be VERY helpful. Thanks.
  • 1 more comment
  • Anonymous Apr 06, 2008
    water flow does not shut off,or drain
  • kinslee Apr 06, 2008
    water is leaking form machine the whole time washer is running.
    [email protected]
  • mattyj36 Nov 26, 2008
    water leaks into bin and does not stop.
Replace the water inlet valve. 285805
Posted on Apr 03, 2008
6ya staff
SOURCE:
How do I get the back off my Kenmore series 80 top loading washer as it leaks whenever the water runs into the tub.
Assuming that this is a basic top load, direct drive washer, see the following for how to release the console and remove the cabinet.
You have access to the back with the cabinet removed.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=f7bdcb299ddb4775bcbd861c65245dc4
May 19, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 leaks in
yip no worries pump is the same as phillips/whirlpool 5min job only 2 clips
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Water leak
Replace the water pump. They will leak.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer leaks water,
on the back of the machine there a two water inlet valves, these are electric solenoid valves and one of them is leaking.  You need to remove the back panel on the washer to replace this valve assembly.  It's a common easily obtained part.
Dec 30, 2008 | Kenmore 24902 Top Load Washer
Kenmore 80 series
suspect sand/rust has gotten past screens inside water valve or screens are missing allowing residue to get into valve ..replace valve ..clean screens as needed in future but be sure to reinstall
Nov 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
372 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
