Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Powershot sd 630 has started taking blurry pictures. battery is charged
  • dempster391 May 18, 2010
    thanks by disasembly i got it working, not sure if it was a cable but i did blow it out good. thanks again
  • Canon Master
  • 3,083 Answers
The most likely cause (if the lens is clean) is that the focusing ring has jammed or is sticking due to dust, or it has become dislodged, and isn't moving. The focusing ring has tiny electromagnets on it, and it rotates as signals from the microprocessor control it. You can try a couple of things to fix it. First thing, is to spray some compressed air into the front lens area. This will often dislodge any dirt or sand that may have worked it's way inside. If that doesn't help, lay the camera on a towel or soft cloth, on the LCD side, with the lens facing up. Hold the camera firmly, and tap it gently with your palm of your hand somewhere where there aren't any switches. What we're hoping for here, is to jar the focusing ring, and make it reseat itself. Try it 2 or 3 times, then take a pictures, and check to see if the focus is restored. This method seems to work about 50% of the time, but if it doesn't, service will be required. There is a possibility that the ribbon connector from the focusing ring to the cpu board has become slightly ajar, and to reseat it, the camera will have to be disassembled. The lens assembly can be expensive to fix, laborwise, so make sure you get an estimate before having it serviced, if all else fails. Sometimes the cost of a new camera on sale is less than the cost of repair. Good luck, hope this helps.
Posted on May 14, 2010
How do I unlock my on/off button on PowerShot SD 630
I don't know that there is a lock on the on/off button. Take the battery out for a minute, put it back in and try.
Oct 04, 2014 | Canon PowerShot SD630 Digital ELPH / IXUS...
My canon powershot SD 1000 is taking fuzzy pictures
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Canon PowerShot SD1000 Digital Camera
Most pictures that I take with my Canon powershot SD 1200is, come out blurry.
Try pressing the shutter button halfway before you take your picture. This opens the lens for exposure and also triggers autofocus based on your camera settings. Once you do that and aim your camera properly, you can press the button all the way to take a photo.
Dec 14, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Canon sd 630 camera won't turn on
Inside the camera, check the brass contacts where the battery connects to the camera. Clean it with rubbing alcohol (use a cotton swab) and try to turn it on after insterting the battery.
Jan 29, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Canon Power Shot SD 630 Digital Elph
When was the last time that you replaced your rechargeable battery? It was only meant to last a couple years, regardless of the amount of its use. If the battery is old, a generic replacement is relatively inexpensive these days. Look for those rated 4 or 5 stars:
http://www.amazon.com/s/qid=1241307462/ref=sr_st?keywords=nb-4l+battery+-charger&rs=172282&page=1&bbn=172282&rh=n%3A172282%2Cn%3A%21493964%2Ck%3Anb-4l+battery+-charger&sort=price
May 02, 2009 | Canon PowerShot SD600 Digital Camera
Card locked!
my camera Canon PowerShot SD630 DIGITAL ELPH/DIGITAL IXUS 65 out off work the lenc dsnt work bcose the battry was lowa atar the my camera stop intel now no work please inser me thank you
Oct 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
