Question about Hotpoint RGB745 Gas Kitchen Range
How do i remove an ignitor/glowbar from a hotpoint gas stove model number RGB745BEH4WH
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about that....
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 14, 2010
Hotpoint gas stove with electric ignition, model # RGB745GEV2WH -- oven will not come on -- I played with the knobs and got it to come on once tonight but can not duplicate that. Oven will simply not turn...
That's you ignitor. They get weak. If it has a glow that is dim orange that is a sign. Another sign of a weak glowbar is you can kick the oven and make her lite off. themobilian_467.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2010 | Hotpoint RGB535 Gas Kitchen Range
My kenmore gas stove with electric start oven will not come on
Their are several different types of ignition. If yours has a glowbar then that glowbar/ignitor has to draw 3.5 amps to open the gas safety valve. If it takes more than a minute or 2 to fire off or not at all OR you can smack the stove and make it fire off then that there ignitor/glowbar is weak. I have a video HERE
Feb 24, 2010 | Kitchen Ranges
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
My oven does not light , only the propane comes through , and i have to shut it down , does not get up to temp
Your glowbar ignitor part number 5303935066 must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
The part is approximately $65 thru the Sears parts site.
Dec 28, 2009 | Kenmore Kitchen Ranges
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
The oven comes on but won't heat up
Replace the glowbar ignitor. Remove the oven racks and then the bottom base pan in the oven to access the glowbar ignitor.
If you have a volt/amp meter place the clamp on amp meter over one wire of the ignitor.Turn the oven on. If it reads less than 3 amps,replace the ignitor.
Nov 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas stovetop works but oven will not come on. Digital display shows that it is on but the oven does not come on.
sounds like you have a bad gas ignitor. It is under the bottom plate and sits on the burner and is held in with 2 1/4 inch screws.8273075 should be the part number for your ignitor....the model number you gave is incomplete so it's hard to tell but hopefully that will help you out
Oct 04, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a Hotpoint range model RGB745BEH. The oven
Check the glowbar ignitor in the oven. If it does not glow or glows weakly replace it. If you are handy with a amp meter you can check the ignitor. If it shows 3 amps or less,replace the ignitor.
Sep 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
310 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
