Question about Motorola Mobility V365 Cellular Phone
I have a v365 phone it makes calls and i can hear everything some one says but they can not hear me . i have changed both front and back speakers still does the sams thing could you help me thank you randy parker
I am not hearing from my phone when somebody is calling me. I only hear when I quickly select loud speaker on. What might be the cause of that?
there are two speakers on your phone one at the back of the phone which is your loud speaker which is working perfectly on your phone and the other one is at the top front center of your phone which has gone bad just take it to the repair shop and get the speaker changed.
Dec 26, 2010 | Nokia 6300 Cellular Phone
When I get a call, I cannot hear anything from the other side without speakers on. Also my playback failed with "No media file found"
Your listen/speaker/media device has a problem,probably destroyed/damaged through excessive dust particles or either exposure to some form of liquid. solution is to change your speaker phone.
Dec 20, 2010 | Sony Ericsson W760i Cellular Phone
My w595 phone speaker does not work , i can`t talk with other.
Play a asong to check whether the problem is with the speaker or the phone. If you hear the song when played through walkman then , Check whether the volume of speaker is low. for this make a call. when you see the call in progress on your display press the rocker keys on the side of your phone to adjust the volume of the speaker while making a call.
You can chage the volume by the roker keys provided with the symbol "+" and"-" Sony walkman series phones stores two different levels of volume for the call and for the Multimedia.
If the volume is full and still the sound wont come then follow these steps.
If you have the proper tools >>remove the battery. >>open the back cover of your phone >>open the front panel of your phone >>carefully unscrew all the screws visble >>now take out each part with care.(samo needs extra care while pulling out from the base board.) make sure you dont break the borad. now you gain access to the speaker near the speaker port. use an eraser to rub and clean the terminal s of the speaker as well as the mother board of the phone.(Dont rub too hard or else you will damage the phone) >>now put everything back and switch on your phone. You should be able to hear the sound.
if you still dont hear the sound replace the small speaker( you already know how to remove it as you have opened the case once) it wont cost more than 2 or 3 dollars.
if dont have the proper tools >>Go to the nearest dealer/shop and hand over the phone to them. Let them do their job. They will replace the speaker immediately. wont take long
Dec 02, 2010 | Sony Ericsson Cell Phones
Having problem with my Motorola V365. I can not hear anything on phone. need to use speaker Help
Hi, The earpiece of the phone you are using is bad. The earpiece is a small speaker inside the phone that allows you to hear when someone calls. It is collected close to where you put your ear when you are making calls.
When you replace the earpiece, the phone will work properly.
Have a nice day.
Sep 25, 2010 | Motorola Mobility V365 Cellular Phone
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
The main speaker (receptor) do not work
The problem why you cannot hear the person you are talking to with the one at the top front(the main earpiece) is that the front earpiece of your phone is bad that is you cannot hear anything unless you put it on speaker.
All you need to do is to replace the front earpiece of your phone and you will see that you will hear when you are talking to anyone.
Change the front earpiece as advice and you see that you will hear your conversation when calling or receiving calls.
Take care.
May 09, 2010 | HTC Touch HD Smartphone
I have a Motorola V365 phone. For various
Contact your service provider and have them re-set your email account. After that, you'll press & hold the 1 button on your keypad and set up your email as if it were new.
Apr 26, 2010 | Motorola Mobility V365 Cellular Phone
Motorola V365, Can't hear anything unless on speaker
Hai,All flip models have this kind of problems....better  take it to the near by authorized supportive center...May be they will advice you to replace the Flip!!!
Aug 03, 2009 | Motorola Mobility V365 Cellular Phone
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Sometimes rings, sometimes not
your phone might have fallen from your hand and the internal jack of your speaker have got damaged. you should readjust your speaker from servicing center or just change your speaker of your phone
Jul 25, 2008 | Motorola Mobility V365 Cellular Phone
Motorola Mobility V365 Cellular Phone Logo
15 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
