Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
To configure the wireless settings on your router, you need to access the setup page using a wired computer.
On your browser's address bar, type www.routerlogin.net.
Default username is admin.
Default password is password.
Once in the netgear setup page, go to Wireless settings.
The default SSID (wireless network name) is NETGEAR. You may change this to any name that you want so that you may identify which is your wireless network.
You may also enable the wireless security. For example, WEP. You may generate a passphrase. Make sure you take note of the key1 because this will serve as a password to connect wirelessly on your wireless computers.
Once you have completed the wireless settings on the router, your wireless computer should be able to detect the SSID. When you connect, it will prompt for a network key. Type the key1 that you get from the router's setup page.
I hope this helps!
