Question about Gateway GT4010 (RBGT4010) PC Desktop
System will not boot up - fans are working
Powered machine down for the night - powered it up the next day and nothing on the monitor. Fans are working - nothing on the monitor - no beeps
  • 2 more comments
  • Ken Clemmer Mar 30, 2008
    Terry,
    Thanks for the info. Yes, I have reset everything known to man in this system. Hard drive is fine, I was able to connect it to another system via Slave and extract the critical information off of it. One thing I will do is the RAM cleaning thing of the contacts.
    Thanks again.
    Ken
  • majordadsage Mar 31, 2008
    I have the same problem. If I unplug the power cord for about 1 minute and then plug it back in, the system comes up fine. I replaced the power supply and thought I had it fixed but, it started doing it again after just one boot.
    I think it might be a motherboard problem?
    John
  • Ken Clemmer Apr 27, 2008
    I raised the white flag and kept the hard drive, memory, and power supply and trashed the rest!
    Shame, it was a good system for 2 years.....
  • Anonymous May 05, 2008
    I had the same problem, system will not boot up - fans are working at full speed and nothing happens. I replaced the Mother board and that solved the problem. I got a Mother board out of Legend Micro in Cleveland Ohio.
    $74.
    Sergeant:
  • 349 Answers
If the pc posts
(power on self test) and you see stuff on the screen, no matter how short , do the following: (this checks for a software problem)
  • when booting up press F8 and when you get to the menu, boot up into safe mode,
  • then restore the pc back to a date before you had the problem, and/or remove any program you installed prior to you having the problem,
if that don't work Try
  • a bootable anti virus disc use it to check for any viruses , if not
  • try a recovery disc, or operating system disc ,
  • both disc's will try to access the hard drive. if they do not work,
  • (nothing has changed) nothing comes on the screen.
laptop does not post:
(then it is a hardware problem)
  • Remove any hardware you may have installed prior to you having the problem.
  • remove the ram and clean the gold edges both sides, with rubbing alcohol or a pencil eraser,
  • and re-insert them, (not an ink eraser as it will do damage)
  • swap them around if you have more than one, try one at a time.
  • if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible,
  • or take the ram to your local pc shop and ask them to check it for you (they may do that for you)
  • if you can establish that the ram is ok, and recovery /system disc's do not work, then it is most likely, that the motherboard has failed .
  • Generally a dead hard drive would not stop the laptop from posting.
good luck with that and let me know how you get on.
Terry
Posted on Mar 30, 2008
  • Anonymous Mar 30, 2008
    i have assumed you have checked all cables from the monitor, to the pc are seated properly,
    replace LAPTOP with PC
    Terry
    it may be that the monitor has died
SOURCE:
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
HP Pavilion a1150y fans run when powered on but windows doesn't load, monitor, mouse and keyboard do not work. (Running Windows XP)
Believe it or not, it's due to a weak power supply. More specifically, weak voltage rail/s caused by failing Electrolytic Capacitors.
A bad computer power supply is about 70% of computer failure.
ALL the light use less than 1 Watt. EACH fan uses 2 to 3 Watts.
A processor uses 55 to 125 Watts. Depends on the make and model.
Since the power supply is weak, it doesn't have enough power to turn the processor on.
No processor, nothing to find the Boot record on the harddrive. Nothing to get the Operating System going. (Example: Windows XP)
No computer running, there is no signal to the monitor.
Just enough power to light lights, and spin fans.
Apr 13, 2009 | HP Computers & Internet
Gateway 831gm not booting. Fans come on but no boot process.
2 questions:
When you say new motherboard do you mean an actual new motherboard or new to that machine, but came from another used model?
When you say you tested the power supply do you mean with a voltmeter/ammeter or put it in another computer and it worked?
I worked on several gateways with similar problems and it boiled down to motherboard issues.
I tested it by replacing the power supply with a bigger (used) power supply and it worked great (for 1 time) and then put the other power supply back in to confirm my diagnosis and yep it wouldn't boot. The next morning I was going to run some virus/malware cleanup and installed the other (known good) power supply and it would not work. I tried all day to get it to boot and it did about twice in a 4 hour period. When it did run it would run great but any attempt to restart it would cause it to crash. No ryhme or reason, it would not fail the same way more than twice. Sometimes beeps, other times no beeps, sometimes it would start up with no video (could hear the Windows starting sounds) other times it would start up normal. I could let it sit and it would start or I could keep trying in sucession and it would eventually start. Some times the fans would slow down from a roar, sometimes they wouldn't. So with a known good power supply that had 150 more watts than the original I diagnosed it as a failed motherboard. But if you have put in a brand new motherboard then I would replace the power supply, because a bad power supply does not mean no power, just not enough power. Please post back and let us know what you find out.
Mar 31, 2009 | Gateway 831GM PC Desktop
When I turn on my computer, nothing appears on monitor
Somehow, if you've been messing with your computer, uv put static through the motherboard. This has ither damaged the processor or chipset, the chipset is the part that makes the usb, display and everything work.
Theres no way out of this except replacing the motherboard and processor. If you went inside your computer, you've obviously damaged something.
Next time wear an antistatic wristband!
Mar 01, 2009 | E-Machines eMachines Desktop PC
HP proliant dl 360 g3 error code 1611 cpu fan failure
Remove all 6 fans, and then remove the fan rack itself. Then tighten the 2 pcb thumb-screws underneath. I believe this is sometimes the reason for false 'failed fan' reports.
Feb 02, 2009 | HP Compaq ProLiant DL360 G3 Server
Unit will not Boot up
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
Computer
Can think of only three possibilities:
1. CPU fan motor, bearings needs lubrication or replacement;
2. Power Supply fan motor, same as above or any of the other fans;
3. Hard disk spindle motor (though unlikely).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Computers & Internet
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Gateway GT4010 (RBGT4010) PC Desktop Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
