Question about Kenmore 46462 Front Load Washer
Whirlpool LSR7233DQ0 agitator slipping
Pretty handy and think I can fix this. The agitator is working but it is weak. What can I do to fix this?
    President:
  • Kenmore Master
  • 2,651 Answers
Part number 80040 heres video on replacing it
http://www.youtube.com/watch?v=f67gGXtK2I0
Posted on Apr 03, 2008
SOURCE:
Whirlpool ultimate care II agitator seems as if it is not woking properly
this is for the whirlpool washer,if you grab the top of the agitator can you spin it both ways without it grabbing,it should only spin one way,if you can spin it both ways you have bad dogs,the agitator cam kit part number is 285809 and it's around 13 dollars.pop off the center cap of the agitator,remove the 7 1/6 inch screw in the middle and pull off the top of the agitator to get at the dogs,you'll see them there are 4 of them,they waer down and the top of the agitator doesn't work.watch this video.
http://www.youtube.com/watch?v=ensJz0h6wLM
Jan 10, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hello; I have a Whirlpool LSR7233DQ0 washer. It will not agitate nor spin; however, I do hear the motor spinning. It will empty the water in the tub. I'm guessing the problem lies in the gear...
it sound like the motor coupling has broke,, you will need to take the pump off of the motor, then remove the motor,, the coupling isa three part piece, two little white three prong pieces, one on the motor and one on the transmission then the black rubber piece that connects them
Jan 23, 2011 | Washing Machines
Whirlpool top load washer. Agitator seems to be wearing out. It barely turns now. if you apply pressure to top of agitator during wash cycle it will agitate. Sound like the agitator is stripped out so...
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 17, 2010 | Whirlpool Washing Machines
Series 90 NO spin and WEAK agitation, good coupler, will drain. The spin tries to go but can't. It sounds like the engine is turning. Agitation happens slowly but can be stopped with no effort at all....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Then see the Whirlpool / Kenmore Service manuals for top load / direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
And see the Whirlpool Parts list (transmission parts)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It sounds like a lot of documentation but It should be worth it.
It sounds like broken cams in your transmission.
(Don't be alarmed, if you're reasonably handy, you can fix it yourself for a lot less than a rebuilt or new transmission.)
See the following for how to remove the transmission and clutch.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Remove the clip that holds the Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and pull the gear off.
Check the Neutral Drain Assembly cams and springs.
We had a problem where the spring that forces one of the plastic cams into the spin pinion was broken so the washer wouldn't spin. (A $15.00 FIX)
Also check the Agitate Cams (they can wear) and the spring that holds them down. If the spring is broken, the machine may not agitate and you'll be able to easily turn the agitators. (Agitate Cams Around $10.)
Basically, you're checking for anything that doesn't look as it should based upon the manuals.
Apr 14, 2010 | Kenmore 15864/15862 Top Load Washer
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator slipping
Replace the coupler. It is located between the motor and the transmission. I think it retails at about $8.00.
Apr 01, 2009 | Whirlpool LSQ8243H
Whirlpool untimate care II won't spin/agitate.......
Welcome gonecamping
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
In the Whirlpool it could be this.
Or a door latch
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 46462 Front Load Washer Logo
228 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
