Question about Bosch Dishwashers
My Bosch SHU 3030 gets stuck during the washing cycle and will continue to run indefinately until the wash cycle knob is rotated a little bit, then it will work fine for a few more minutes until the knob gets stuck again. Whats my solution?
5 Suggested Answers
SOURCE: bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Posted on Jan 13, 2009
  • 2468 Answers
SOURCE: Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Posted on Mar 23, 2010
  • 3247 Answers
SOURCE: bosch diswasher ( SHU 3035 UC) stops at every
Best to replace the timer module which looks like this.
You can find the details of the assembly in these diagrams.
Hope this helps. Please make sure the mains power is turned off when working in the dishwasher.
Posted on Oct 19, 2010
Daniel S
  • 4323 Answers
SOURCE: My Bosch SHU 5315UC timer stays at 2Hours, and
Hi
This issue is either due to short circuit or moisture on the control board. You'll need to access the control panel by removing the front panel from the dishwasher. Part#1A is the control module.
To remove the front panel---
1.Remove fascia panel by removing T-20 Torx inner door screws.
2.Disconnect wire harnesses from module after noting connector locations.
3.Pry out metal console tabs holding module to console.
4.Carefully pry back plastic tabs, then slide module from console.
Hope this helps... Please post back for further assistance.
Daniel
Posted on Nov 25, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
I have a Hotoint Ultmia WMD947 washing machine. The countdown timer shows 1 minute left of cycle, but somtimes the cycle continues indefinately unless we restart with another programme, and even then it's...
It's probably due to the heating needing replacing. It may be covered in limescale if you're in a hard water area. My Bosch Logixx would stay at the 1 minute mark for a couple of hours, continually washing. If the wash cycle is not hot (you can feel the glass door to check) then it is very likely the failed heating element. You can order a spare for around 50 pounds (make sure you get exactly the right one for the model), and fit it yourself in around 30 minutes if you find the right online tutorial on YouTube. Replacing the heating element fixed my machine.
Aug 28, 2013 | Hotpoint Washing Machines
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
May 04, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
I have a bosch washing machine make is a exxcel 1200 express and it stops working in the middle of a cycle and the words f04 come up wot does that mean please
there may be a stuck in cycle of rotating knob kindly rotate the knob more than three times your problem will be sloved otherwise replce the mechanism
Dec 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Timer (cycle knob) gets stuck on occaision and
possible that its the timer more likely an internal blockage main wash water level not being reached and activating heater if the water does not reach temp selected for any reason the appliance will stick at the heating phase also if your dishwasher is getting old over 10 years wiring loom in door may be breaking down, will need service to sort out
Nov 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
May 11, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
142 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
