Question about HP w17e Monitor
No volume, speaker icon on bottom left shows a red "X"
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 74 Answers
It's not because the monitor. It's from the sound card. Maybe you muted it.
Posted on May 14, 2010
I get picture on Viber laptop, but no sound. How do I get speakers to work and where can I find the speakers.
Check to see if you a speaker icon in the lower r/h side of the task-bar down by the clock.
If the icon is not there right click on a blank area of the task-bar and left click 'properties'
Left click 'customize'
Scroll down to 'Volume' and select 'Show icon and notifications "
Click 'OK'
Close the 2 properties pop-ups.
Right click on the speaker icon and select 'playback devices'
The 'sound' pop up will appear showing whatever you have connected ( speakers or headset etc)
Make sure the speakers are set as default if you have more than one sound device connected.
The speakers should have a green tick (check ) when they are ready to use
Right click on the speaker icon and select 'Open volume mixer"
Check that the volume slider is above 50% and the speakers are not muted (shown as a red no-entry sign on the speaker icons at the bottom of the sliders' If muted click on the slider speaker icon.
Right click on the speaker icon and select 'playback devices' Put the cursor on the blue graph to the right of the icon, right click and select 'test' All being well the computer speakers will respond.
Dec 03, 2016 | Cell Phones
Why nobody hear me on skype
turn your speaker on .,works for me every time I keep my speaker turned off all the time .
Sep 07, 2014 | SKYPE Computers & Internet
Microphone not working
Have you tested your microphone in Sounds under the Control Panel?
Nov 23, 2013 | HEWLETT-PACKARD HP Pavilion G72b66US...
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Speakers don't mute with headphones on
When you plug headphones into a laptop computer, the laptop speakers are usually cut off automatically. However, if you wish to do this manually, there is a way. One common reason for shutting off the speakers is so that your quiet workplace won't fill up with sound if you should unplug the headset for some reason while playing music or performing some other sound-filled activity.
Muting the Speaker but Not the System On a typical laptop running Windows, left-click on the double chevrons of the "Show hidden icons" button in the Quick Launch toolbar at the bottom-right corner of the screen. This will display all your hidden quick-launch icons, and usually these will an include an icon of a speaker that launches the "Volume Control" utility. If not, then you can also access the Volume Control utility from the Control Panel, via the "Sounds and Audio Devices" application. Simply launch that application, click on the "Volume" tab, and click on the "Advanced" button in the "Device volume" section. In the Volume Control utility, click on the "Advanced" button near the bottom-left area of the window. Near the bottom of the advanced controls window, there will be a section labeled "Other Controls." Here you should see some kind of check-box option labeled something to the effect of "PC Speaker Mute." If you check that box and save your changes, the laptop's speakers will be shut off, but you will still be able to listen to any music or other sounds through your headset. It's as simple as that. To cancel the shutoff, simply uncheck the box and save your changes. This method works for all versions of Windows still widely in use. Hope this helps.
b>
Dec 23, 2012 | LG E500 Express Dual Series Notebook PC
Speaker icon is red. I can mute and unmute, but remains red and I have no audio
If the red icon is the speaker icon at the right bottom of the screen then follow this:
  1. Go and click on the icon at the bottom right of the screen (the speaker icon)
  2. Use the dial to change the volume and this should unmute your speakers
Hope that helps. If not then please specify your problem a bit.afzalnabil_0.jpg
Apr 30, 2011 | YouTube Videos
I have no voice at all, how wood i get my volum ajusted.
Hi!
1. If it is visible, single left click on the 'Show hidden icons' button, which is usually located near the bottom right hand corner of the screen. 2. Single left click on the 'Volume' icon, which looks like a gray speaker.
3. Single left click and hold down on the slider in the 'Volume' dialog box. As you are holding down on the left mouse button, drag the slider up to raise the volume or drag the slider down to lower the volume. When you let go of the left mouse button, you should hear a tone to give you an example of how loud the volume is now set. 4. Single left click on the on the blue 'Taskbar' to make the 'Volume' dialog box disappear.
Hope this helps. :)
Apr 16, 2011 | Dell Dimension 2400 PC Desktop
Dont know how to control the volume, i cannot find my manual
Most of the time their are multiple ways to do this.
1. On the speaker in the lower right hand corner left click and a volume bar appears. Slide it up and down. It should be adjust to 75% IMO.
2. On your keys there should be symbols that look like speakers that should match the color of you "fn" key. Press and hold the fn key and then press the corresponding speaker key to increase or decrease the volume.
3. There may be a rotary volume control on the front of the laptop case. It's as simple as turning it to increase or decrease it.
On the volume bar in windows verify that the muted in unchecked.
Mar 10, 2011 | Computers & Internet
How do i unmute microphone i can hear them but they cannot hear me
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it
Jan 22, 2011 | Skype IM
I lost sound in my computer and i also don,t what,s real problem ,please help resolve this problem
Look in your task bar (bottom right) for the picture of a speaker...it will show "volume" when you hover over it. Double left click on the speaker icon and it will show the "Master Volume window"...make sure none of the "Mute" is checked, if they are the un-check them.
Also bring up all the "sliders" to the top. This will give you max volume.
Good luck,
Hope this helps
Oct 30, 2009 | Audio Players & Recorders
HP w17e Monitor Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
