Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Clicking noise My hard drive fell to the floor while uploading a few files and suddenly it started emitting this strange clicking noise. It wouldn't let me disconnect it and it won't be recognized on my computer anymore. What do I do?
    President:
  • 2,600 Answers
The clicking comes fro damage done to the read/write head hitting either the swing stop or the heads are out of alignment and clicking the edge pf the platters. The drive is mechanically damaged and cannot be serviced with extensive cost. If you need the data, you will have to get the drive to a data retrieval company.
Posted on May 14, 2010
Toshiba MK1059GSM sudden noise?
First backup all your data asap. Noises of this type are a sign of a failing drive.
Then run the extended test... http://gsmartcontrol.berlios.de/home/index.php/en/Home
You should be able to replace the drive with in the one year warranty period.
Sep 12, 2012 | Toshiba (MK1059GSM) 1 TB Hard Drive
My dell optiflex system started acting slow. OS installed is windows 7, Ram - 4GB usable - 3GB. i re-installed the OS using the re-installaation CD provided by DELL but found no improvement. i woould...
Test the computer's Hard Drive. There are a lot of reasons you might want to test your hard drive for problems. One of the major reasons to perform a test would be if your hard drive is making strange noises. This can often be a sign of a failing drive, something a test can point out.
If the problem is a software issue (virus or too much software installed on the PC) running a System Recovery should have fixed the problem. Try running a test on the computer's Hard Drive. A failing Hard Drive causes slow performance (slow boot, slow computer performance, programs takes too long to load or will not laod at all). And another indicator that the Hard Drive is failing is clicking noises. If you hear clicking noises, backup your files as soon as you can.
You can use free Hard Drive diagnostic tools what can be downloaded from the internet. One of them is Seagate Seatools.You can download it from here - click this link
SeaTools for Windows can perform several basic tests that can help determine the health of your hard drive. Your available hard drives and tests are easy to see when the program opens and can be ran with just a few clicks of the mouse.
Hope this help. Goodluck!
Apr 07, 2011 | Dell OptiPlex 780 DT/ 780 MT/ 780 SFF...
Strange clicking sound from my book home edition 1TB. Disk is not visible in any system Mac or Windows.
Is the clicking sound continous? Did the disk fell down or did something else hit the dis? The symptoms are bad for the data you have in the disk... If the sound isn't constantly, leave the disk on the computer for a long time, it's possible to work again....
Stelios.
Feb 22, 2010 | Western Digital My Book Home Edition 500...
1997 sable with 12000 miles electrical problems
earth cable from body to engine and battery to chassis ,clean the connections and fit an additional cable ,also clean and grease the battery terminal
Jan 25, 2010 | 1997 Mercury Sable
A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Hitachi Deskstar T7K250 HDT722525DLAT80...
There is a strange sound when I try to start the drive. Discovered that +5vdc is missing on CON3. Can the 5v-power supply be repaired or, if not, can I just take the HDD and save the data to another...
You have quite a few options but the noise you mention concerns me.
If it is like a regular clicking sound then it may well be the drive that is at fault
You were correct in thinking you can move the drive.
Remove it from its enclosur (treat it with care it is a hard drive not a flash drive). Place it in a computer with a suitable interface eg. SATA or IDE (check you drive for which)
If you power up the computer and can copy and paste a small file to and from the drive it is probably fine. and you can buta new enclosure of the correct type and put it in there.
If you can see the drive or copy files and it still makes any clicking type noises or other unusual noises then the drive will be at fault.
If the drive is faulty and you have mission critical data on there then you may wish to send the drive to a recovery specialist but this is not cheap
Aug 21, 2009 | Maxtor Shared Storage II (S01R320) Hard...
Odd clicking noise...
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
Jun 12, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
External USB drive making clicking noise - Windows does not recognize it!
it is going to crash soon as the platter seems to broken it is non repairable yes but u can save the data by taking help of any good tech
May 19, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hitachi 500GB External- strange tones at startup, won't recognize
It sounds to me like there is a seek problem.Is this the sound coming from the inside the box itself? If so, that is NOT good. Usually when you hear crazy noises like that from a hard drive, its internal damage. I imagine when you tripped on the cable and it fell to the ground, it exceeded the g-force rating for the drive. That and the fact it was under power and doing read seeks, the heads could have crashed. I guess you could disassemble the unit and hook up the hard drive as a slave inside your computer and bypass the external unit to see if that solves it. Its worth a try. It really does sound like its not a good situation. Sorry about that. I hope this helps!
May 13, 2008 | Hitachi 500GB External USB 2.0 Hard Drive
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
331 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
