Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
What is the longest bar i can go on my 455 rancher saw ?
    President:
  • 2,220 Answers
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 14, 2010
  • 23 Answers
Depending on chain condition and wood, 20" bar may be a bit much. Even razor-sharp, in tough woods. Some say 16" bar is better-suited to this saw. That's so for full-comp chains. A sharp full-skip 20" chain can be buried in just about any wood. 24" bars can be had in K095 mount. A 24" full-skip chain would work pretty well on this saw, so long as it's kept suitably oiled.
Posted on May 22, 2014
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Loosen or tighten chain on a 445 Husqurna Rancher chain saw
If this is the tooless system, flip open the wing on the bar cover securing nut, slacken off one turn, now use the knurled wheel in the cove to slacken, or tighten the chain, if it has two 13mm bar nuts, slacken them off one turn each, then use a flat blade screw driver through the side cover, betwwen the bar nuts to adjust the chain, the screw is quite small so clean away the saw dust to locate it.
Oct 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
No chain oil feed
not sure if the 455 rancher is the exact same as my rancher but when the oil feed on my saw seems slow i remove the chain and bar and clean the chain grove. pay special attention to the end that is near the motor there are a couple of places that allow the oil to flow from the saw body to the chain groove and then subsequently to the chain
Feb 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Lou
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Jun 29, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
983 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
